Tip & How-To about Samsung Cell Phones
4 Methods to Transfer Data from iPhone to Samsung Galaxy Note 8
Samsung Galaxy Note 8 catches our eyes with its infinity display, creative S pen, high-performing 10nm mobile processor, 6GB RAM. And for better new phone experience, Samsung Galaxy Note 8 also makes effort on transferring old phone data to new Samsung Galaxy Note 8. This article will show you how to achieve one-click transfer data from iPhone to Samsung Galaxy Note 8 in a professional way.
More about 4 Methods to Transfer Data from iPhone to Samsung Galaxy Note 8
Cell Phones Logo
How to Transfer Contacts from iPhone to Samsung S8?
Phone to phone Transfer tool can help you transfer your contacts from iPhone to Samsung phone. You just need to connect your two phones to the computer, and select the wanted contacts to transfer.
This way is effective and safe, the software will not carry any risks to damage your phones.
Learn more information about how to transfer contacts from iPhone to Samsung phone.
Contacts Transfer between iPhone and Samsung Samsung Data Transfer
Apr 25, 2017 | Samsung Cell Phones
How can i transfer contacts from samsung to galaxy s8?
Luckly, we can share you the method to Transfer Contacts from Samsung to Samsung S8 with Samsung Data Transfer.
More steps details info from:
Transfer Data Contacts from Samsung to Galaxy S8 S8 Edge Free Mobile Transfer Transfer Data from Phone to Phone
Apr 19, 2017 | Samsung Cell Phones
S Pen for my Samsung Note 3 stopped working how can I fix it
Samsung Galaxy Note 3: S Pen stopped working on screen:
Hello. The S Pen is not powered by a battery per se. The screen on your phone generates a magnetic field. There's a coil inside the S Pen that captures energy from the field to power the pen.
1. Question are your S Pen options turned off?
Settings>Controls>S Pen>
turn on Direct Pen Input
turn on Air Command
turn on Air View
2. it could be the pen tip that is worn out and needs to be changed. Check the tip by pressing it into the pen with your finger.. if you feel the tip going into the pen too far, it's probably the tip that is broken or worn out. Some customers say buying new tips is too much trouble, and getting a new OEM Samsung S Pen made for your Note 3 is a safer option.
3. it could be the wacom digitizer screen that is having problems on your phone and needs to be fixed. If you had fixed the screen prior, it could mean the person who installed the replacement screen could have did a bad job.
4. if you are using a magnet closure case, try taking it off and then using your S Pen. Because the external case magnet can interrupt the magnetic field the S Pen uses for power rendering it useless, until you remove the magnetic closing case.. and then all should be well again.
5. You can do tests on Note 3's that are not carrier locked by dialing *#0*# (this is not a solution but it can help eliminate possibilities)
DIAGNOSTIC TEST your Pen for Samsung Galaxy Note 3
6. If you bought an Aftermarket knockoff S Pen, that's probably the problem right there. A lot of non OEM Samsung S Pen's have their own issues and work for only some things.
7. You can try fixing the sensitivity of the S Pen
8. Buy an original Samsung Galaxy S Pen. A Note 1, 2, 4, or Note 5 S Pen will work for your Note 3, but it may not fit inside the Note 3's internal compartment/holder. You can try buying a used one to save money, but be aware that you might have to change the tip
Feb 08, 2016 | Samsung Galaxy Note 3
note 8 still freezes on startup screen after factory reset
you should call to company where you have bought or even better to go in with it
Mar 23, 2014 | Samsung Galaxy Note GT-N5110 16 GB Tablet...
272 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
