Tip & How-To about Troy-Bilt Garden
Change Oil, Spark Plug & Air Filter
I show how to do the annual maintenance on this push mower. This includes changing Oil, Spark Plug & Air Filter on a Troy-Bilt TB110 push mower with a Briggs & Stratton 550EX engine.
Garden Logo
How do you clean the carberator on a tb110?
Take the bowl off of the carburetor take off float and remove needle.
clean the needle the reinstall everything.
That usually take care of the problem with small engine fuel problems.
Jun 10, 2014 | Troy-Bilt Electric Cultivator Tb 154 110v...
Bought a Troy TB110 oush mower at end of last summer. I stored it all winter without opening box. I got it out today, put together and started it. It is leaking oil and blowing white smoke- What do I need to do?
You must have stored it with the spark plug end down. This has caused the oil to get by the rings and on top of the piston. Pull spark plug out and pull starter cord to clear excess oil , put plug back in . Check oil , start mower and let it run until the excess oil burns off and some of it may still be in the muffler. Mower is ok. Some body borrowed my mower and did this resulting in the same problem.
Apr 10, 2011 | Troy Bilt 5.5hp Self Propelled Mower
where is the oil change plug
The plug is under the mower on the bottom of the engine. Make sure you take the spark plug wire off before you work, remove the blade (it needs sharpening anyway right?) and then tilt the mower on its side WITH THE CARBURETOR UP. position an aluminum cake tin under the mower so that once you remove the oil plug using a 3/8" ratchet you can set the mower back down over the cake tin and it will catch the oil. Don't forget to put the plug back in =-)
Jun 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
won't start after 3 seconds it stops
try changing or cleaning the spark plug and scoket
Aug 18, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
Aug 07, 2009 | Troy Bilt 5.5hp Self Propelled Mower
295 people viewed this tip
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
