Tip & How-To about Miscellaneous
Air Bag Quick Fix
Any Car Airbag Warning Light !!!
if your airbag light is on and no code? 1. pull battery negative cable if it does not go out .once done 2. go under your seat look at the wires going to the seat's check for wire disconnections kinks in wire try to replug un do any wire that should look shorted ..that should fix it without replacing sensor look real good when you shove things under seat it will cause this problem by disconnecting wiring etc please be sure to check this out Good Luck !!!
If This doesnt work theres other trick's right on this site !!!
We Are Here To Help !!
Donald Deane MCSE,ASE,CPO
Miscellaneous Logo
recently changed lock cylinder on a 97 jeep wrangler and airbag light came on. Why?
DID YOU REMOVE AIRBAG FUSE OR DISCONNECT NEGATIVE BATTERY CABLE TO DISCHARGE AIRBAG CAPACITOR DISCHARGE BEFORE YOU REPLACE IGNITION SWITCH KEYLOCK CYLINDER. CHECK MAKE SURE YOU INSTALLED AIRBAG FUSE OR IF YOU DID DISCONNECT NEGATIVE BATTERY CABLE.WHEN YOU RECONNECT NEGATIVE BATTERY CABLE.WITH IGNITION SWITCH ON POSITION FOR MINUTE THE AIRBAG LIGHT SHOULD TURN OFF.IF NOT HAVE GARAGE OR DEALERSHIP CODE SCAN AIRBAGS SYSTEM SEE WHAT CAUSE SRS AIRBAG LIGHT TO FLASH ON COULD HAVE FAULT IN SYSTEM..
Nov 08, 2011 | 1997 Jeep Wrangler
chevrolet silverado 2004 airbag sensors reset
The airbag in your vehicle is an important safety device, and the airbag module ensures the proper functioning of your vehicle's air bag. If this module is not functioning properly, your airbag may not deploy during a crash. When there is a malfunction, your airbag module warning light will illuminate on your vehicle's dash. You will need to have the airbag assembly checked out by a qualified mechanic, but once that is done, you can reset the warning light and airbag module unit. If you've never done this type of job before, it should only take you 5 minutes.
    • 1 Open the hood and loosen the retaining nut on the negative cable wire cable clamp using a socket wrench.
    • 2 Slide the cable clamp off the negative battery terminal.
    • 3 Wait 3 to 5 seconds and reconnect the battery terminal. Tighten the retaining nut using a socket wrench. Once the power is restored, the airbag module should be reset.
    • 4 Verify that the module has been reset by turning the ignition key to the "II" position and checking to make sure that the airbag light does not illuminate.
Oct 08, 2011 | 2001 Chevrolet Silverado
i put a new battery in my 2005 kia sorento and now the air bag light comes on and stays on once i have started the car
When the airbag light (SRS) is on or blinks it means a fault has occurred in the system and the airbag diagnostic monitor has disabled the system, the most common problem that turns the light on is a break in the connection to the steering wheel mounted airbag, this is due to a rotating ribbon contact that breaks under the steering wheel that connects the airbag to the wiring harness and the diagnostic monitor, the part is called the clock spring contact, a coiled up ribbon electrical contact that turns with the steering wheel while maintaining a mechanical connection to the airgag mounted on the steering wheel, to replace this part you must disarm the airbag system and remove the steering wheel, this requires a special steering wheel puller tool and that you disarm the airbag system before you start the work, to do this disconnect the battery negative cable for 1/2 hour prior.
Apr 25, 2010 | 2005 Kia Sorento
Airbag reset code combination?
first re check the connection then to reset the computer take the positive cable from the car off the battery and give it 3-5min to discharge then touch the positive cable from the car to the negative cable (still attached to the battery) for about 5 seconds and then hook back up the positive post and that will reset the computer.
if that doesnt take the code off (turn the light off) then the connection is bad that you unhooked or there is a cut in one of the wires you unhooked or you shorted it out when you put it back together and you my need a new one.
Mar 28, 2009 | 2002 Nissan Maxima
253 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
