Tip & How-To about Toshiba e-Studio 350 Copier
Toshiba E-Studio 3508A 35PPM Monochrome Copier Machine
The e-STUDIO 3508A Series comprises an A3/LD- size monochrome MFP series that offers print speeds of 35 cpm/ppm. The series is designed to put a fast, efficient, secure MFP in the hands of small and medium workgroups. Not only is it high-volume, it also produces high-quality type and images.
Medium & High workgroups need to get a lot more done often using fewer resources and minimal space. That's the thinking behind the e-STUDIO 3508A too. Plenty of functions, lots of capacity, and a small footprint with a fresh, new look.
General:
Print & Copy Speed: 35 ppm (A4) & 25 ppm (A3)
Warm-up Time:Approx. 16 seconds from low power mode
Paper Size & Weight:Cassettes: A5R-A3, 60-256 gsm , Bypass: A5R-A3, 52-256 gsm
Paper Capacity:2x 550 sheets (Cassettes), 1x 100 sheets (Bypass), Maximum 3,200 sheets
Inner Output Tray:550-sheet capacity
Automatic Duplex:A5R-A3, 60-256 gsm
Controller Type:Toshiba e-BRIDGE
Control Panel:22.8 cm (9") Multi-Touch Colour Panel
Memory:Toshiba Secure HDD 320 GB1), 4 GB RAM
Interface:10Base-T/100Base-TX/1000Base-T, High Speed USB 2.0, WLAN2)(IEEE802.11b/g/n), Bluetooth2), Wi-Fi Direct2)
Dimensions & Weight:585 x 585 x 787 mm (W x D x H), ~58 kg
COPY:
ResolutionScan: 600 x 600 dpi
Print: 2,400 x 600 dpi with smoothing
First Copy Output Time:Approx. 4.3/4.3/3.6/3.6/3.6 seconds
Zoom:25-400% (Platen), 25-200% (RADF/DSDF)2)
Copy Modes:Text, Text/Photo, Photo, Custom
PRINT:
Resolution:600 x 600 dpi, 2,400 x 600 dpi (with smoothing), 1,200 x 1,200 dpi (2 bit, PostScript driver only), 3,600 x 1,200 dpi (PostScript driver with smoothing only)
Page Description Languages:PCL5e, PCL5c, PCL6 (PCL XL), XPS and PostScript 3 compatible
Supported Systems:Windows 10/8/7/Vista/Server 2008 (32/64 bit), Windows Server 2012/Server 2008 R2 (64 bit), Mac OS X 10.6.8-10.11, Linux/Unix, Citrix, Novell NetWare (NDPS), SAP, AS/400
Network Protocols: TCP/IP (IPv4/IPv6), IPX/SPX, EtherTalk, NetBios over TCP/IP
Print Functions:Universal Printer Driver, Driver Templates, Driver plug-ins2), Print from USB, Hold print, Tandem printing
Mobile Printing: e-BRIDGE Print & Capture, AirPrint, Mopria Print Service, Google Cloud Print
SCAN:
Resolution:Maximum 600 x 600 dpi
Scan Speed:Reversing Automatic Document Feeder 2): up to 73 ipm (300 dpi) in colour and monochrome
Dual Scan Document Feeder 2): up to 240 ipm (300 dpi) in colour and monochrome
Scan Modes:Auto-Colour (ACS), Colour, Greyscale, Monochrome
File Formats:JPEG, Multi/Single Page TIFF/XPS/PDF, Secure PDF, Slim PDF, Searchable PDF2) (and other formats like DOCX, XLSX, RTF, TXT, PDF/A)2)
Scan Functions: WS Scan, Scan to USB, Scan to E-Mail, Scan to File (SMB, FTP, FTPS, IPX/SPX, Local), Meta Scan2), OCR Scan2), Scan to Box (e-Filing), WIA, TWA
Toshiba Studio 3508A
Toshiba e-Studio 350 Copier Logo
canon ic-1320 toner rubs off copies
if toner rubs off then fuser unit is not heating paper to fuse toner to paper. You may notice paper printed on is not hot .
Jul 14, 2016 | Canon imageCLASS D1320 Laser Multifunction...
What does error n9 indicate?
You may call on 877-372-5594 (Toll Free) for help.
Dec 03, 2015 | Xerox WorkCentre 5020 Laser Multifunction...
My printer won't print its sending blank papers through.
The ink/toner is probably out. Do you have the correct drivers for the device also?
Dec 02, 2014 | Brother MFC-J470DW Inkjet Multifunction...
How to remove streaks on the canon d1300
Hello, That is either your toner or your fuzing unit. Or you need a maint. kit.
Oct 02, 2014 | Canon imageCLASS D1300 D1370 Laser...
how to get in to service mode on a lexmark x782e mfp
Diagnostics mode: power off unit. hold the 3 and 6 buttons and power on, holding the buttons for 10 seconds
Configuration mode: same as above but hold the 2 and 6 buttons.
Aug 30, 2014 | Lexmark X782E Laser Multifunction Printer...
368 people viewed this tip
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
