Tip & How-To about Garden
Sprinkler Head Won't Spray Fix
I show how to fix a dead sprinkler head by removing and cleaning the sprinkler head without removing or replacing the entire sprinkler assembly
Garden Logo
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
I installed a sprinkler head and no water is spraying out
Is the sprinkler like the one shown? Is it rising out of the ground?
May 11, 2014 | Garden
Sprinkler will not pop up
Sounds like "Sure pop" was misleading. Try unscrewing the top or entire sprinkler then the top remove the spray nozzle to access the spring. Stretch it out longer and re-assemble the sprinkler screw it back in place with the spray notches on nozzle facing are you want covered. This should solve the problem if not, replace the pop-up.
Jul 15, 2013 | Rainbird Sure Pop 600 Series 2-1/2" Pop Up...
I WANT TO REMOVE THE ENTIRE - POP UP HEAD LIGHT FROM "98 CORVETTE
why not just disable the motors while in up position?
Aug 25, 2009 | 1998 Chevrolet Corvette
77 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
