Tip & How-To about Dell E176FPB 17" TFT LCD Flat Panel Monitor
Powers Off and Won't Stay On Fix
I show how to fix a DELL Monitor that will power off a few seconds after being turned on.
Dell E176FPB 17" TFT LCD Flat Panel Monitor Logo
my monitor is a dell 2000 flat screen 20.1" turns
This is a backlight problem. The picture is there but there is no light from behind the LCD screen. It could be due to faulty capacitors, which are easy to replace. It could be a faulty Inverter transformer, which is harder to fix but he backlight controller board can usually be replaced at a reasonable price. If you have soldering experience you may be able to replace the faulty capacitors - look for capacitors with bulging tops.
Repalcing the inverter board in a job for someone with electronics experience. You can buy a universal inverter board for about £15 to £20 from e-bay.
20 inch monitors can be bought for about £100 to £150 so you need to decide whether it is economical to repair.
Feb 18, 2011 | Dell UltraSharp 2000FP 20.1" Flat Panel...
It is not so difficult to repare if you have scills to open the monitor and scills in un-soldering/soldering electronic components, than yes it is worth it, but if you go to a shop they have a tendency to sell you another monitor since the price they charge to repare the powersupply is about the same as a new monitor
my dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
monitor goes dark
If the power light turns yellow, there is no signal being received by the monitor from your computer's graphics card. The screen will shut off (go into idle mode), which is a low-power state, that saves energy. Check that the cable on the back of your computer is plugged into the right graphics card (many PCs come with more than one, these days). There may be one built into the computer's mainboard, and another one may be on a separate graphics card located somewhere else on the machine. Only one of these will work on startup. If one doesn't work, try the other.
Apr 23, 2010 | Dell E176FP 17" LCD Monitor
256 people viewed this tip
Clive
Clive
Alun Cox
