Tip & How-To about Health & Beauty
What Shall I consider before going for Hair transplant?
Hair transplant is the surgical process of replanting your hairs from the back of scalp ( i.e. Donor Area) to hair loss or baldness affected area ( ie. recipient area). It is a day care procedure & doesn't require hospitalisation (unless any complication arises). Still, Hair number of hair transplant patients suffer from Hair transplant complications. Here by I will share you the tips and common failing points for most of the patients.
1. Is Hair transplant right choice for me
It is the most common failing point for the number of patients, especially for young ones. As we know, hair loss can be a very daunting phenomenon for one's personality, it can make one to pursue prematurely for hair transplant. Hair transplant is successful only when it is done at the right time & right age.
2. Is hair transplant permanent solution
Hair transplant can be a permanent solution for people who are going under the knife in the late 40s or in 50s. Averagely, Transplanted hairs stay on scalp for 25-30 years, then they fall off cause of ageing of the body. Also, hair transplant remains for that much time only when proper after care and maintenance is considered, otherwise they won't last for a long time.
3. How to choose & what makes the hair transplant clinic best?
After considering 2 points, this point makes the very crucial step in the process of hair transplant. This can make or break your entire efforts and money put in. To summarise, I will run through very important points quickly, rest you will find in blog, I have mentioned.
1. The credibility of Surgeon: Who is Surgeon? What are the Credits? No. of Successful Surgeries?
2. Surgical Infrastructure: Compliances & Standards followed, Condition of Operating Infrastructure, Sterilisation Practices followed?
3. Technical Staff: Experience, Skill and Training
4. Results: What is the number of successful hair transplants?
5. Patient testimonials: Experiences Speaks!
6. Social Media: Todays, most effective way of conducting research. look what people have to say about them.
I am sure that, if you follow these minimum steps, then also your chances of getting successful hair transplant increases by odd 30%. If you have any doubts or query you can feel free to ask me here or on my personal email at drdhananjay.social@gmail.com
Health & Beauty Logo
Are there any possible risks of undergoing hair transplant surgery?
There are no proven risks or side effects associated with hair transplant surgery. Feeling of itching and discomfort is usually experienced for a period of 3 to 4 weeks but these tend to disappear as time. Feeling of pain is also minimal as the surgery is conducted giving local Anastasia. While i underwent hair transplant surgery in Seager hair transplant center in Toronto I was given local Anastasia prior to surgery.
Jan 15, 2014 | Health & Beauty
Can my hair transplantation done look natural ?
Hair transplant is a procedure where we transplant hair roots from donor area to the area where there is baldness. These hair roots may have one to four hairs. Implantation of the roots must follow a natural pattern. Creation of Hairline is most important. It may be called as a signature of hair transplant surgeon. Hairline should be placed according to the age of the patient. Too low hairline gives a transplanted look. Also low hairline will remain to be there for lifelong, as we transplant permanent hair here. So as age increases this will hair transplant results in an odd look.
One thing should be kept in mind that donor's hairs are limited, so use them judiciously to give the best possible result. At our centre, with the advantage of FUE, we do hair transplant by taking follicles from beard and chest also, beard hairs are thick so they give good volume. This is known as BHT (body hair transplant).
Rejuvenate hair transplant in India
Aug 21, 2013 | Hairart Health & Beauty
Are the hair transplant results permanent?
The process followed in hair transplant is by taking healthy follicles from part of body which is having enough thick and dense hair, usually the back of your head. So the hair are natural and gives you best result and long term appearance.
Affordable Hair Transplant Cost In Ahmedabad at Avenues Cosmetic Avenues...
Jul 19, 2013 | Hairart Health & Beauty
Which is the best method for hair transplant? FUE or FUT?
Different Between FUT and FUE Hair Transplant Method
1- FUT there is a linear long cut is given on the back side of the head to harvest a skin strip. The wound is closed with sutures. After healing there is a long liner cut which is covered by adjacent hair. This scar will show after shaving. FUE Method means follicular unit transplant in which individual hair follicles are harvested without giving any linear cut and no suture is put after surgery. There is a circular punch which is mounted on the motorized handle. The head is completely shaved. After giving local anaesthesia grafts are harvested.
2- The general population does not like a long linear scar and they feel it is a surgery or operation in which head is cut. So more or less it is a fear factor.
3- As far as technical aspect is a concern the FUE done by the untrained surgeon than chances of follicle damage is much more as compared to FUT. But much of work is done by an assistant in FUT so it is very important to have a well-trained assistant for FUT Method.
4- The harvesting of follicles in FUE and strip harvesting in FUT is done by the surgeon and also surgeon makes slits while implantation is done by assistants. In both a good trained qualified surgeon and assistants are mandatory.
5- Chances of scar widening, hypertrophic scar painful scar is there in FUT while chances of these are much less if done properly.
Read More -
Hair Transplant Technique Difference Between FUT and FUE Method
Does Propecia work for hair loss?
On One Hand: Propecia for Hair Loss According to Drugs.com, Propecia (finasteride) is a prescription drug used to treat male pattern baldness by preventing testosterone from turning into dihydrotestosterone. A double blind placebo clinical study showed significant increases in hair count at six and 12 months of Propecia treatment. On the Other: Possible Side Effects Drugs.com states some side effects exist and might affect the usefulness and ability to continue using Propecia. Some are listed as swelling in the hands, testicle pain, impotence, dizziness and abnormal **** . Allergic reactions do exist, leading to hives, swelling of the throat, and difficulty breathing. Bottom Line Propecia is a clinically-tested, effective treatment for male pattern baldness, but side effects might reduce the effectiveness of the drug. Consult with your physician on what prescription is best for hair loss.
Nov 23, 2010 | Health & Beauty
115 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
