Tip & How-To about Miscellaneous
How To Use A Spotting Scope For Shooting
If you practice hunting and shooting, a spotting scope is one of the best instruments that you need to have to provide you with a clear view when you are aiming at your target. Before we get started on how to use a spotting scope for shooting, it is great if you know what exactly a spotting scope is.
Precisely, a spotting scope is a small device that is used for many outdoor activities to magnify and help you watch images and objects closely. Before purchasing the best spotting scope for shooting, you need to know a few things that will help you use it well in your shooting career. Here are some things that you need to know when using a spotting scope for shooting.
Comfortable Position Is Key
If you want to get the best performance from your spotting scope, ensure that you position yourself in a comfortable place. You know when you are using a spotting scope you will be holding it for long so it is very crucial to find a comfortable place that you can sit or lay down depending on what you find best. Make sure you find a comfortable place and learn more about the specifications of the area which should be the point of targeted area.
Attach Your Scope To A Tripod
Sometimes holding your scope with your hands can compromise the quality of images that you get because of shaking and fatigue. If you want to achieve a clear and accurate view, get a tripod and attach to your scope. This means that your scope will be very stable because there are minimal movements so you end up getting very accurate results. When you are using a tripod, the chances of missing your target are very minimal.
Adjusting The Magnification
You should also adjust the magnification of your spotting scope to a level that you like. Spotting scopes are designed differently so you need to know how to adjust magnification and the lens layout of your scope. For the most accurate results, it is great if you read the instruction given about the magnification levels and how to adjust.
In some spotting scopes, you need to use the lens knob so that you can zoom in and out of the magnification. In other scopes, you need to use the small zoom in and zoom round trigger on the point of the eyepiece.
View Target Area And Adjust Magnification
When you are using spotting scopes, it is not advisable to go with the magnification first because you might not get the right results. The best thing that you can do is to view the target area first and then adjust the magnification effectively.
Reset Focus In A New Area Always
This is very important because a sudden highly magnified glass can cause problems to your eyes. This means you can feel uneasy when you are watching your target longer. This results because of watching at a very high magnification glass for a prolonged period. You can overcome the problem by reducing the effect of the magnify glass on your eyes.
Beating The Sun
If you want to become a spotting scope pro, you must learn how to beat the sun. You need to know how to deal with the frustrating heat waves because they quickly distort your view and it becomes difficult to grass. The best way in which you can beat the sun is to zoom out. Zoom out to a lower power setting and you will enjoy heat-wave glassing hours. You should wait for passing cloud because they reduce the heat wave and give you the chance to zoom back in your target.
Final Words
Buying the best spotting scope for shooting is not enough. You also need to learn how to use it so that you can get clear and bright images all the time. This will help you gain accuracy when you are shooting so no more missed shots. If you learn these tips, you will not experience any problem when you are hunting or shooting. Knowing how to use your scope is the only way in which you will get most out of it when shooting. Best Spotting Scope to buy in 2017 Buying Guide Reviews
Miscellaneous Logo
Suggest a high-quality spotting scope for hunting?
According to me one of the best and a high-quality spotting scope for hunting purpose that is Barska spotting scope. Before buying this spotting scope you can check the Barska scope reviews. If you will watch all the reviews you can make a perfect choice for buying a high-quality spotting scope.
Dec 08, 2017 | Optics
Good day my is Wade my Swiss Arms air rifle has got no power when shooting.
there is no air rifle suitable for south african hunting conditions.
Sep 09, 2016 | The Optics
Rim or Centre fire
If it will be your first gun then rimfire as its cheap ammo so can get lots of practice . low recoil and great for learning the basics of shooting
Centerfire is more powerful and can shoot farther so can be used on larger game but ammo is that little bit more expensive depending on calibre used
So it comes down to what you want out of your shooting what rimfire does at short ranges centerfire does at longer ranges ballistically speaking
Mar 11, 2015 | Optics
what size rings do i need for this scope
Choosing scope rings involves the following considerations:
1. Get the right diameter. Most scopes are 1.00" in diameter, but not all of them. Measure your scope tube.
2. Mount the scope as close to the barrel as is practical. The closer the axis of the scope is to the axis of the bore, the less error is introduced by canting the rifle.
3. You must have proper eye relief. If you are shooting a high-power rifle, you need at least a couple inches between your face the the end of the scope to allow for recoil. This is less important for low recoil calibers. You must also be able to position the scope so that you get a full field of view when you mount it to your shoulder to shoot. Some rifles, like Ruger #1's are tricky to get right due to the shape of the action. Some rings are offset to provide additional adjustment room.
Jan 04, 2015 | Optics
never shot this size of hand gun before, have shot a ruger 357 mag 150 grain bullet. what bullet would you recommend to shot with?
Shoot it with .38 special cartridges to practice trigger control and function drills (less recoil). Save your .357 for hunting, self protection, and familiarization fire. The weight of the bullet is not overly important, construction is. hollow points for self defense and hunting medium game. Rule of thumb? Light weight and fast for humans, heavy weight and slower for medium game.
Dec 18, 2013 | Optics
69 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
