Tip & How-To about Miscellaneous
Ways to Make a Portable Generator Quieter
Generators play a crucial role in your home, especially if you live in an area that experiences frequent power blackouts or you love camping in remote areas with no connection to the national grid. However, the noise generators produce can cause disturbance to family members, neighbors or fellow campers. So, is there a way to capitalize on its benefits while lowering the noise it produces is to bearable levels? Yes! Reducing generator noise is not only possible but also simple. It involves initiatives such as installing a muffler, using a generator baffle box and using a soundproof generator box. Continue reading for a detailed explanation of these and several other ways to quiet a noisy generator.
1. Using a muffler
This method involves buying a super quiet generator muffler and fixing it to the exhaust pipe. Mufflers work by allowing exhaust air to pass through while limiting noise transmission. It forces air through splitters which in turn reduces the wavelength of sound thereby reducing its loudness. So, as your generator runs the muffler absorbs noise substantially making your unit quieter. However, since mufflers come in different sizes, some even designed for motorcycles, you should exercise caution while shopping for the same to ensure you acquire the model and size that will suit your generator. Ask the dealer for some guidance on how to muffle a generator and if the model you are considering will play the role. Generally, the bigger the muffler, the greater the noise reduction it will produce.
2. Build an enclosure
Hard walled surfaces restrict noise transmission by reflecting back the sound your generator produces making it significantly quiet. So, create generator baffle boxes using hard materials such as wood. Enclose your unit in the enclosure, making sure there is sufficient installation for it to run both safely and smoothly. Generators emit harmful gases, and since you will need to refill the fuel and service it from time to time, insulation is crucial. You do not have to hire the services of a skilled carpenter to adopt this method; there are many DIY (Do It Yourself) generator quiet box plans available online for you to use. Put into consideration your generator size and any other special requirement and construct a wooden house to reduce the noise your generator produces.
3. Insulate the Enclosure
Using a hard material to build a generator noise reduction box only restricts noise within the room. So, to reduce noise as well as reverberations inside the enclosure/plant room, you must insulate the space so that it can absorb sound. So, how will you achieve this objective? There are two ways. You can line the hard generator enclosure surface with sound-absorbing materials such as hardened foam, or you can install special acoustic wall panels on the inner walls and ceiling tiles for the top. Either way, you will adequately soundproof generator box thus reducing the noise your generator produces. Use the insulating material extensively within the enclosure, and your neighbors and family members will not even realize your generator is running. This approach works equally well for generators used for camping and tailgating.
4. Install it at a Distance
Increase the distance between your generator and home, camping location, the residential area or your customers, and you'll be surprised by how much noise you can reduce. Consequently, this method is the most affordable (since it doesn't involve purchasing any material) yet the most effective. When you move the unit far away, the sound wave travels over a greater, and as such loses lots energy along the way. The noise that finally reaches the community contains less acoustic intensity which implies that it will be of low volume. Every time you double the distance separating the unit and yourself, you reduce the noise level by six decibels. So, place it as far as possible, taking care not to position your generator at such a distance that it'll be at risk of theft, damage or even meddling by antagonistic individuals.
5. Change the orientation of the exhaust pipe
Most people make the mistake of installing horizontal pipes that direct the noise the generator produces in a particular direction. If you are in a camp, and the exhaust accidentally points towards you or to another group, the noise can simply be unbearable. So, what is the solution? Modify the exhaust pipe to face upwards. Acquire an extension tube, bend it to face up and attach it to the end of your generator's exhaust. Alternatively, if your generator is compact and portable, turn it around so that its exhaust is pointing upward. In such an orientation, your generator will channel the sound waves upwards, thus appearing less noise to people around it. You may only have to put up with a slight change in appearance, but the resulting substantial noise reduction is definitely worth the sacrifice.
The benefits of using a generator are many. Do not allow generator noise to curtail your camping expedition, annoy your neighbors or even interfere with your sleeping pattern. With the above expertly recommended guide on how to make a generator quiet for camping, you can make your generator silent enough to use for tailgating as well as in any other setup. While some of the approaches require special gadgets such as mufflers, others are considerably less costly as they involve using locally available materials. Settle for the method that is practically possible in your situation and meets your budget. Do not forget pay attention to any precautions for your generator to run efficiently and remain safe.
Ways to Make Portable Generator Quieter
Miscellaneous Logo
I want to be an actress (13) but I can't afford lessons?
Can you start a club at your school? Or just start an acting club with your friends. Find a few plays in the library and try reading through them.
Jan 04, 2017 | Theater
Can I buy a hygiene kit for my camping trip or do I have to buy each item separately?
Goodquestion - it might be cheaper to buy the items individually especially if youare going to be camping frequently, but if your trip is a one-off, then gettingan all in one camping hygiene pack is a great solution. Amazon have them foraround $6 which seems like a good pricehttp://www.amazon.com/Essentials-Personal-Survival-Disaster-preparedness/dp/B001E8RE3I
Aug 02, 2012 | Camping, Backpacking & Hiking
2005 SXT appears to open power side doors on its own. Maybe kids pranking or stray signals in area? Usually happens at nite. Anyone else experience?
i think kids playing with a remote for something else and they have found it works on your vehicle ,disconnect the battery before you go to bed then they will lose interest
Aug 18, 2010 | 2005 Dodge Caravan
i search the '' Perfect MMORPG''what is?
Definition: MMORPG is an acronym for Massively Multiplayer Online Role-Playing Game. These are role-playing games where thousands of gamers play online in a virtual and persistent environment on the Internet.
Usage: If you have a natural tan, you probably aren't a hardcore MMORPG player.
A Massively-Multiplayer Online Role-Playing Game. An online game that is very similar to windows 95 with ICQ and a fantasy background. Double-click everywhere to kill an endless stream of monsters in a fantasy world and gain new powers. Do this for hours on end while chatting with someone named "Drizzt23" or "MikethePike" about where in Korea or France or Alabama you live and what was on TV last night. Contrary to the name, these games do not feature role-playing, so don't worry. Perfect for people who are too slow for Counter-Strike, and with no friends or imagination for role-playing. A: "Caleb played 34 hours of Lineage 2 this weekend!"
B: "Wow, how many levels did he gain?"
A: "That was amazing, he gained 4 levels!! Unfortunately, he got a cramp in his mouse-finger and had to quit."
B: "Awesome, he's a true role-player!"
May 28, 2010 | Microsoft Windows Vista Home Premium...
Blades stopped on my 02 cool fan.
I love the 02 Cool rechargeable/battery operated fans and have them running in my home and office daily. However, they do have a limited lifespan. I get about 6-9 months of daily use before the fan motor goes dead and the blades stop turning. However, I'll keep buying them. I live in an area where we frequently lose power and the rechargeable/battery operated feature pays off when it does so on a hot day.
Jun 25, 2009 | Panasonic Dryers
53 people viewed this tip
Top Miscellaneous Experts
Randy Hughes
Randy Hughes
Joey Gammon
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
