Tip & How-To about Heating & Cooling
Dryer Not Drying
Before thinking the issue could be a big one always clean out the vent pipe this should be done at least yearly to keep performance of the machine up and safety reasons. This is a great item to use to do this: LintEater Dryer Vent Lint Removal Kit White
Heating & Cooling Logo
kenmore elite 62042 says it is done, but, always requires some more time and seems to be progressing towards longer drying times. the clothes are warm but still damp. started 6-12 mos. ago, 5-10 min extra needed...now about 20-30 min needed. I have cleaned (with a brush) behind the lint screens a couple of times. the lint screen still captures lots of lint so I believe airflow isn't the main problem. are there humidity sensors that would shut it off before it is done. I have had it for about 9 years. I pulled the pipe to the outdoors down a couple of years back out of fear of fire from lack of maint and 5-7 years hadn't plugged the pipe. are there any distinctly common issues with this model that fit this situation?
Here are a few more things to look at:
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Dec 19, 2009 | Dryers
dryer says check filter and it is clean
Air flow in the duct work is restricted... and the dryer sensor thinks that the filter is clogged.
You will need to take a fluffy cleaning wand and, with the filter removed, try loosening up some of the accumulated line in the duct.
Next, remove the lint pipe from the wall connector and try cleaning it and the pipe for as much distance as you can reach.
Finally, go outside and check the vent. It needs to be clean and clear of obstructions... also, needs to close when the machine is off.
You can do testing on the outside vent with "air dry" setting - hot air is not required... Keep cleaning ductwork until the outside vent passes air freely.
After air flow is restored, the sensor in the "VENT" alarm will act nice.....and stay off
Nov 01, 2009 | LG DLE2514 Electric Dryer
whirlpool dryer not drying
your dryer is likely clogged up with lint .. that would be after the lint filter .. the pipe that carries the hot air out is usually completely clogged after that long .. it and the dryer itself (down inside) has to be cleaned about once a year to keep it tip top .. hopefully you can find someone that can take it apart and clean everythiing .. that should get you back to like new performance .. or you could call a few handymen to see what they would charge to clean the lint from your dryer and stack .. or if you are handy there is a special big brush with a string attached .. you pull that thru the stack to clean it .. use a vacuum cleaner to get inside the dryer vent (you can see in the vent when you take the hose off .. excessive lint buildup not only greatly reduces your dryers efficiency but is a fire hazzard as well ..
Aug 12, 2009 | Whirlpool LER5636P Electric Dryer
Heating Element no longer working
Hi Paige
Expect to pay $30 for the kit. it's a 279816 and will take some level of mechanical and technical ability to locate it and affect the repair. This kit addresses 2 issues and should be installed by a certified technician. Your owners manual has a big WARNING!!! block saying what not to do, like Don't use plastic or foil venting. But nobody reads manuals anyway. Most likely you have an aluminum foil colored accordian style vent pipe. That's what caused your thermostats to burn out. Get your drier checked out by a certified tech for safety. Afterwards, keep that vent, clean clean clean and install a sure vent from Whirlpool 4396028. 16,000 homes each year have fires from improperly vented driers according to the U.S. Dept of Consumer Safety.
Dec 10, 2008 | KitchenAid KEYS750LQ Electric Dryer
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
424 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
