Tip & How-To about Samsung HC-P4363W 43 in. TV/DVD Combo
Try this if tv keeps turning off
This problem started with me when I plugged in a digital audio to me tv. If you are using a digital audio cable unplug it and see if problem persists.
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
Turned my tv on and for some reason the DVD source is in black and white and controller not workin for it, TVs colour for other outputs and controller works only DVD that doesn't .
If you're using component cabling (red, green, blue cables) a black and white picture will occur when only the green cable is plugged in.
If you're using HDMI cabling, try a different HDMI port and see if your color comes back.
If not, unplug the set from power for a few minutes, plug it back in and see if problem persists.
If you still have the same problem, check the DVD player on another TV. If it shows color on a different TV, then your TV will need a replacement digital board which we can check availability on once we have a specific model number. If it's black and white on a different TV, then you have a problematic DVD player.
Dec 15, 2012 | Televison & Video
connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
DC doesn´t has image
try a different av cable or jiggle the connectro on the dreamcast av port
Apr 10, 2008 | Sega Dreamcast Console
US-144 noise
Hi
Usually Noise comes from distortion such as Electricity (50-60Hz), Main reason audio input cables might have shielding problem. Make sure cable is connected well and shield is not destroyed. You can understand it when you unplug the input connection and use the Computer volume by playing a digital media. If distortion persists contact to TASCAM @+1-323-727-7617
Good Luck
Jan 11, 2008 | Tascam US-144 Sound Card
surround help
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
Jun 11, 2007 | RCA RT2390 System
854 people viewed this tip
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
