Tip & How-To about Steamfast SF-680 Digital Steam Press Iron
Steamfast 680 Steam Press won't heat
FYI: Steampress 680. I have owned this Steam Press for almost ten years. I had one side would not heat up. I took the machine apart and discovered it was a corroded and rusted connector. I took the wiring (cleaned it up) and soldered to a new connector. Then put it back together. To remove the top portion of the steam press, first remove the six small screws around the teflon side of the press. Then remove the gray plastic screws on the arm hinge. Next remove to the two small screws next to the the silver knobs of what "locks" the unit in the carry position. Then with a screwdriver, pop the black plastic cover off. You will need to be careful and "push in" and lift around the silver lock nubs and then the top cover is removed. With a 10mm rachet, remove the two lock nuts and the washers. Be careful to leave the springs in place. This will allow the heating element to drop down and then you can see if a connector is corroded. Remove the aluminum shield by removing the nuts on top (There are four). Hopefully you have fixed everything and when you put it back together, place the aluminum shield back down with the nuts. Then start with the the small six screws on the Teflon surface. These clips will need to make sure that the hook is toward you. This will allow the hook to capture the small ridge on the silver cover. Leave the six screws someone loose until you can maneuver them enough to "pop" the silver cover down on the Teflon service. Then once completed, align the two screws on the top (between the locking mechanism) and then resemble. I would check to make sure the repair worked before you put everything back. Also, support the top lid with something and rest it on the board. It will alleviate the pressure and the possibility of pulling the wires loose. This should save you from buying a new one. I have had to do this twice in ten years but now works good as new!
Steamfast SF-680 Digital Steam Press Iron Logo
My steampress 660 is has black stuff coming out
Hi Beverly. The "dried stuff" is scale which occurs naturally in tap water. You should always use DISTILLED water - buy litre bottles (approx.$2.ea Home Brand) all supermarkets. Electricity off, empty out all the water in your iron. Half fill with distilled water, cover the filling hole, and shake water inside iron side to side, up and down, vigorously, empty distilled water out and watch carefully to see if water runs clear or has sediment coming out - may need to repeat this action. When water runs clear re-fill iron as normal with distilled water. Put iron on lowest STEAM setting, LIFT up iron but with soleplate facing down onto an old rag/towel (brown water may come out) press steam button on & off to try & clear the holes. Turn iron off, allow to cool. Thick cloth wipe soleplate over getting into the holes if they have not cleared. Triple wrap a wooden skewer in cloth soaked in white viegar or "scale remover" and circulate it around the blocked holes. Go very carefully do not scratch the coating on the soleplate or holes - very important. Let us all know how this goes please and if I have been of help, do hope so. Good luck, Chris
Feb 12, 2015 | Irons
steam button on iron has stopped working yet iron still heats up and light on boiler still goes on.
this just happened to us & the electronics man at my husband's plant took it apart & said the thermostat needs replaced. the wires were all eaten up so to speak
Jun 10, 2009 | Rowenta Steam Generator DG050 Iron
Steam Press sp-660 will not steam with distilled water
Steamfast brand SP-660 steam press
contact Top Innovations
Nov 10, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Steam Fast SF 680 arm is hanging up
Top Innovations, Inc.
6655 Troost Ave.,
Kansas City, MO 64131
Dec 27, 2007 | Steam Fast SF-680 Iron with Auto Shut-off
151 people viewed this tip
Top Steamfast Irons Experts
Are you a Steamfast Iron Expert? Answer questions, earn points and help others
