Tip & How-To about Cell Phones
Samsung Galaxy S4 "Charging paused, battery temp too LOW!?"
What I have done to solve this annoying charging problem is to notice over time the USB charging connector does not fully insert into the USB charging port. The root cause of this is dust and lint mostly from where you carry the phone gets packed into the port by plugging it in hundreds of times night after night. Eventually you have a bad/marginal connection.
I solved this by carefully picking out the lint fuzz with the smallest jeweler's screw driver available (a small gage copper wire or dental pick would also work fine). You will amazed by the amount of fuzz that is removed. Keep picking and blowing out the fuzz till you can no longer see any accumulation in the bottom of the port. Use good lighting and an eye loupe or magnifying lens to see into this small space. When your done the connector will be able to insert fully into the port like it did when the phone was new.
I hope this helps you. It is a simple and inexpensive fix.
Cell Phones Logo
my sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
i have connected my nanomax ipod to the computer and it is not charging.how should i charge it?
Good morning, afternoon, evening or night; whatever time you are viewing this solution post. Thank you for choosing FixYa to solve your problem. So you have connected your Nanomax iPod to the computer and it's not charging like it's supposed to, and you want to know how you should charge it properly? There are two ways you can charge the battery - charging via your Dock Connector to USB Cable, or the Apple USB Power Adapter (which is sold separately). Here are the step by step instructions to charging your and Nanomax.
Using the Dock Connector to USB Cable
  1. Using your Dock Connector to USB Cable, plug the dock connector end to your iPod and plug the USB end to your computer. Make sure the computer you are using has a USB 2.0 port (check your computer's technical specifications to see if it's USB 2.0 certified). Most USB ports on the keyboards of laptops do not provide enough power to perform charging activities. If you have a Docking Station, plug the docking connector into the station and placed the iPod in the station as well.
  2. Make sure your computer is fully awake and not asleep (meaning in sleep mode).
  3. A fully charged battery takes 3 hours to complete. An 80% charged battery takes an hour and 30 minutes. The battery is charging when it shows the charging icon (a battery not fully shaded in green, with a lightning bolt).The battery is done charging when the "fully charged" icon shows (a green-shaded battery with a 2-prong plug showing).
  4. When you are done, disconnect the cable from your computer.
Using the Apple USB Power Adapter
  1. Connect the Alternating Current (AC) Plug Adapter with the power adapter (if connected already, skip this step).
  2. Using your Dock Connector to USB Cable, connect the dock connector end to your iPod and the USB end to the power adapter.
  3. Plug the power adapter into a polarized wall outlet or surge protector outlet.
I think you connected everything correctly, but the USB port on your computer did not have enough power to charge your battery. If that's the case, you will have to find a computer that has a USB 2.0 port on it (like a desktop PC or MAC, or a car adapter charging device) and connect to it, or use the USB Power Adapter (sold seperately). I think this pretty much answers your question. I hope this benefits you the best way possible. Once again, thank you for choosing Fixya as your one-stop solution spot for your problems. Have a good day, evening or night; whatever time you are viewing this, and visit us again the next you need assistance troubleshooting.
Apr 27, 2011 | Audio Players & Recorders
Cannot go past usb is connected, or battery charged notice ?
disconnect it from power, then turn it on and after its done booting, use a paper clip and insert it in the tiny hole on the left side (thats the rest) and depress the switch gently...it should now start to reboot, after its done, plug in the charger again....if you still have a problem, let me know by replying to this post.
bill
Feb 23, 2010 | Magellan Maestro 3140 GPS Devices
insignia shuts off on me when it's fully charged
Taking the Battery Off the Insignia Pilot 8GBhttp://www.youtube.com/watch?v=29ULLzZqHLI&feature=related
You may need a new battery.
GoodLuck
Dec 10, 2008 | Insignia Pilot MP3 Player
camera wont switch on (z1 dimage.)
This happened to me too, today! I can't turn on my camera and the usb port is stuck inside the camera (can't plug it in, etc). It's easter, so much for taking photos.
Dec 28, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
109 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
