Tip & How-To about Perma Synthetic Roofing Felt 48"X250 -
Decorating tip
After using your roller for emulsion some paint and decorators use a shopping bag to store it until the next day , two ways to go here get a j cloth and leave it damp, roll up the roller inside the j cloth then put it into a small plastic bag then you can use the bag a lot longer or get a used large Pringle container and do the same thing , the container has foil inside and a plastic air tight lid good one
Perma Synthetic Roofing Felt 48"X250 - Logo
Is wall posters are great for wall decoration purposes?
Yes wall posters are great for wall decoration. A few days ago I bought some bridge framed wall poster for my home from a well known shop (Find the Essence of Joy). Those designs were very beautiful.
Sep 23, 2015 | Canon PosterArtist 2008
How to remove grease splashes from emulsion painted wall
Basically you can't without affecting the Paint underneath ((
If only light splashes then a conventional kitchen cleaner will do BUT only put the cleaner on the cloth, work a small area at a time.
After doing getting it off and allowing it to dry, then use a lint free cloth, soaked in warm water to "scrub" paint from surrounding areas into damaged area but not too hard otherwise will go through the paint levels. Then allow to dry naturally ))
Nov 05, 2014 | Cars & Trucks
how can i get paint off the outer bag i have the g4 its also on the wire thanks
Best way is to use paint thinner. Where some gloves to protect your hands, then put a little paint thinner ( can get at any paint or hardware store) on a semi damp terry cloth towel/rag. And apply it the area where paint is and slowly work it in and, it will de-solve it, and repeat process until paint is gone. Be careful not to have my any open flames and do not smoke around it. Paint thinner is very flammable. Thanks Mike
Jul 18, 2011 | Kirby G4 Bagged Upright Vacuum
I am looking at buying a Wagner Max HLVP sprayer. The jobs are staining a modest stretch of fencng and a larger staining project of an overhead pagoda-type structure. Is this a good choice or would you recomment something different?
I was a painting contractor for last 10 years of my work career.
If you are using HVLC cup gun, you will have to select correct tip,
You will need to thin the latex 50-50 with water, and keep paint strained to keep out all clogging.
If the tip is not reversible, then expect disassemble each time clog happens.
And you will be continually re-filling the cup.
And then if the surface is rough, the spray won't flow into the holes.
You have a mess coming your way.
Painting a fence: A roller is the only way to paint/stain rough surface.
Buy big hairy 1" roller cover from Sherwin Williams. Don't get the cheapo 1/4" thick roller cover because it doesn't hold any paint. The big roller holds a big volume of paint.
Now if fence is rough, like cedar, you need to thin the stain.
About 1.5 gallon water per 5 of stain ... and suddenly you have 6-1/2 gallons of stain which means you bought too many gallons of stain.
So don't overbuy the stain. And pick up 2 plastic bucket for mixing.
Empty gallon of stain into mixing bucket > put water into empty gallon > put lid on gallon and shake up > pour water into mixing bucket with stain > to mix: pour mixing bucket of stain back and forth between other mixing bucket until stain is mixed. Do this work on the grass where it won't run out onto concrete surface.
Put roller and frame on a wood pole that you took off the push broom. Now roll that stain onto every surface the roller can touch. Think of it like picking up quarters. If it was money, could you get the roller on that spot >> the answer is yes. Don't try to smooth it out and make pretty. Throw the stain on any way the roller can turn. Customers used to call that 'slapping it on' and I used to say, 'that's how it works, lady.'
Use a piece of masonite at the bottom. If you get stain on anything, wash it off immediately and use a wire brush on concrete surface or towel on smooth surface.
Wait for a day, because stain looks 100% better next day. And then go back with a brush and hit the spots you couldn't get with the roller. It will be faster and cheaper and fewer headaches than trying to spray latex stain with a HVLP cup gun.
To clean the roller: Leave it on the roller frame and wood stick. Turn on water hose and get the roller spinning until it's clean. Do this away from everything you don't want stain on.
Dec 13, 2010 | Garden
53 people viewed this tip
Top Perma Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Perma Hardware and Accessory Expert? Answer questions, earn points and help others
