Tip & How-To about Garden
Preventative Pest Control for Mowers
Recently, we have had a couple of cases of mice ruining our electrical! The first time was actually in our Honda car, and now most recently in our Ariens mower.. Mice are chewing the wiring, nesting and just ruining the interior!
Our repair guy recommended moth balls - And we ordered parts here https://www.powerequipmentwarehouse.com/ Husqvarna Dealer Stihl Dealer Toro Dealer Unbeatable Prices
Garden Logo
Electrical wiring diagram for 110v outlets on Sunnybrook rv
Mice generally don't gnaw the solid conductor copper in two. They gnaw the insulation and cause a short.
I had a wire come completely loose on an outlet a couple of years after a remodel. That loose wire fed the other outlets in the room.
Cut the breaker and remove all the outlet covers and inspect with a flashlite. If you don't see anything obvious, remove the outlets one at a time til you find something not connected.
It could also be a bad breaker (saw that happen recently ). It looks/is set to 'on' but no power is coming out. The breaker panel will have to be removed to check that. Make sure you have the skills or get an electrician.
Sep 25, 2017 | Electrical Supplies
My Crf has recently started smoking an also harder than normal to start unless choked, only thing I've recently done is changed the spark plug but it still has plenty of power an actually seems snappyier than before I changed the plug so I'm really stumped where should I start!?!
You are probably due for a top end rebuild. Your owners manual recommends a rebuild after several moto's or probably at least twice a year. Most riders can not afford that. I am guessing it may have been a couple of years since your last top end over haul (hone or bore,piston,rings,valve stem seals, gaskets,etc).
Oct 27, 2010 | 2005 Honda CRF 250 R
1989 honda crx hf electric problem
the wiring harness rubs in half. trace the wires from the alternator back. Under the intake manifold about middle ways you should find the broken wire.
Apr 13, 2010 | 1989 Honda CRX
My 94 Honda Accord DX will not idle. I recently
it still sounds like timing,double check time
Nov 23, 2009 | 1994 Honda Accord
car stalls when driving and doesn't restart right away
Fuel filter changed recently? If it just started this & you filled up somewhere you don't normally fill up, then I'd try some "heet" additive or similar to remove moisture from gas tank, just in case that's the problem.$5.00 test.
Dec 29, 2008 | 1999 Honda Accord
85 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
