Tip & How-To about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
How to Choose the Right Swimming Pool Filter?
There is a lot of confusion about various filters, many different opinions, and several important facts to consider. The first is that a pool can be properly maintained with any of the filter systems available: Sand, Cartridge, or Diatomaceous Earth (DE). Here is a brief description of each type:
SAND FILTERS
Water is pushed through a bed of filter sand and removed through a set of lateral tubes at the bottom.
The filter area of a sand filter is equal to the area of the filter itself.
For example, a 24" filter will have 3.14 square feet of filter area. Only the top 1" of sand is actually used to filter the water. The principle behind this filter is that water is pushed through the filter sand, somewhat like an espresso machine. Dirty water goes in the top and clean water exits out the bottom. As the filter sand becomes plugged with debris from the pool, the pressure increases on the filter and the water flow drops. In order to clean the filter, you just run it in reverse and dump the waste water; this is referred to as "backwashing" the filter.
How to Choose the Right Swimming Pool Filter Pool filter reviews
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
When shopping for an LED light for my parking lot, what should I consider?
Not just for LED parking lot lights, but also for other LED lights like LED corn lights, you will have to consider some important factors. Even, there are some less-important factors to consider in your shopping process. For instance, when it comes to the important things to consider, you should check whether the light works with a dimmer. Further, another important fact is the light output in lumens. You should also take into account the CRI or Color Rendering Index, which denotes the quality of illumination and the color temperature. In addition to these important factors, you should also consider other factors like the brand and dependability. When you choose an established online dealer like LED Light Expert, you will get the best collection. Even, you can get professional guidance from this store to help you with the selection of the right DLC listed lights that will rightly meet your lighting needs.
Apr 21, 2018 | Cars & Trucks
Is 40.1 the correct oil mixture for huskvara chain saw
The owners manuals for all Husqvarna products in the US call for a 50:1 fuel ratio. That being said, there are lots of opinions out there... Some believe that extra oil is good protection and promotes longevity of the machine. Some of the confusion may come from the fact that Husky equipment is distributed world wide and some countries specify a more oily mix like 40:1 or even 33:1. A support person explained it to me that different countries have different grades and quality of fuel... If you don't mind a little more smoke and maybe shorter plug life a little extra oil won't hurt, but you may not get maximum power from the device.
Dec 02, 2014 | Garden
Need to know oil mixture for older huskvarachainsaw
.dwg file corrupt?
Different solutions you may find out here:-
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/444-%E2%80%8Berror-cannot-open-file-open-cad-drawing-dwg-format - a lot of different opinions might be your saving.
BAK files are very important, explanation below:
Consider what AutoCAD does during a QSAVE (assuming "create BAK" is enabled)
1. It writes the contents of the editor to a temp file.
2. It renames the current drawing from .DWG to .BAK
3. It renames the temp file to the correct file name with a .DWG extension.
I don't see how you have had problems with BAK files since it's simply a copy of your last save. In fact, if you QSAVE twice in a row, then your BAK = the DWG.
OR
Third party software DWG Viewer Tool
But demo version for free:- http://www.dwg.viewertool.com/
Nov 06, 2014 | Autodesk AutoCAD Computers & Internet
Was wondering how to change the settings on filter. Its a Hayward Pro Series High Rate Sand Filter and the instruction manual says it have about 5 different ones....i.e. waste, recirculate, but we were only aware of the backwash function. There aren't any indicators on the valve to change or position if these options are available
If you know how to place the valve into the backwash and filter positions you need to use these. The others are important at times but they are not as important. In fact another type of backwash valve has only two positions. This valve is one of the most popular valves for this function so it must not be too bad. I hope this helps.
Aug 20, 2011 | Hayward SAND FILTER, PRO SERIES
132 people viewed this tip
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
