Tip & How-To about Electrical Supplies
How to Install Note 5 LCD assembly
Color: Sapphire
Screen Size: 5. 7 inches
Resolution: 1440 x 2560 pixels, 518 ppi pixel density
Material: Super AMOLED capacitive touchscreen, 16M colors
Protective Material: Corning Gorilla Glass 4
Compatibility: Galaxy Note 5
? This Galaxy note 5 replacement parts does not include the front frame.
? This Galaxy Note 5 LCD assembly comes with the stylus sensor film, please do not confuse it with the Galaxy Note 5 LCD assembly WITHOUT sensor film.
? This Galaxy Note 5 LCD and digitizer assembly is a brand new original replacement.
? The Galaxy Note 5 LCD assembly is available in sapphire, gold and white, this is the white one.
? This n920c LCD is compatible with all Galaxy Note 5 models.
How to Install / Tips:
Special repairing tools are required for assembling or disassembling, as the Galaxy Note 5 LCD display and digitizer are hermetically attached.
Handle the vulnerable and fragile flex cable ribbon carefully.
Please try to handle the repair or replacement work in a dry and dust free environment without direct sunlight.
The installation of any new part should be done by a qualified person. Rootmi is not responsible for any damage caused during installation.
Mobile phone replacement parts supplier, choose Rootmi. For Samsung Galaxy Note 5 N920F N920T N920A N920P N920V N920R4 N920C LCD...
Electrical Supplies Logo
Why possible is 300 dpi printing images and text matter
What is DPI PPI and Why Do They Matter
To some extent, we're all photographers these days. With a camera on every phone and digital SLRs coming down in price, we've all got a trove of photos waiting to be shared. When it comes time to share online, print, or email our favorite images, many are unsure about how to set the image's resolution...
If you've found yourself in this spot, don't worry - dots per inch (shortened to DPI from here on out) is a concept that even confounds some professional graphic artists. Here's a primer DPI so you can stop worrying about technology and start sharing your photos.
Getting started
Digital photos are comprised of pixels, much like the individual boxes on a sheet of graph paper. DPI tells you how small those pixels will be when the image is printed. For example, "300 dots per inch" means that 300 pixels fit across each inch. If your photo is 600 pixels tall by 900 pixels wide, for example, it would come out at 2" x 3" inches if you were to print at 300 DPI. Keep in mind that most digital photos are several thousand pixels in either direction, but for the sake of simplicity, we'll use the more manageable 600 x 900 pixels.
Separating pixels from presentation
It's important to separate DPI from the raw pixel dimensions, and this is where even the pros slip up. DPI is not an indication of image quality or clarity. When you print that 600 x 900 pixel image at 300DPI, it'll likely look pretty sharp, because every inch is densely packed with pixels.
Now imagine printing that same image, with the same number of pixels, at a mere 30 DPI. As each inch would have only 30 pixels across, the density drops immensely and the image prints much larger: 20" by 30". What was once sharp now appears blurry, because each individual pixel is now ten times larger than before. By separating DPI from actual pixel count, we can understand that raising DPI doesn't magically improve a photo. DPI simply takes the same data (the original pixels) and alters how we'll view them.
Pin it It's all about context
Another factor is viewing distance. Just think of the eye chart at your doctor's office. If you're a bit nearsighted, the tiny letters at the bottom are illegible specks, while the letters at the top are easily discerned. In actuality, each tiny letter may be half an inch tall, but the distance makes them seem microscopic. Now consider our 600 by 900 pixel image. When we printed it at 30 DPI, the giant pixels made it look blurry. Were we to look at it across the doctor's office long hallway, however, it may look just as sharp as the 300 DPI print did in our hands. This illustrates how DPI is more about context than quality.
Pin it Pixels Per Inch
You'll notice I've been talking about DPI in relation to printing only. This is because while printers can produce a variety of DPI settings, a computer display's resolution is fixed - its pixel density is part of the physical hardware, and cannot be altered. When talking about displays instead of print, most use the term PPI, or "pixels per inch."
If you intend to put your 600 x 900 pixel image online, switching the resolution to 30, 300, or 3000 PPI is completely arbitrary, because the computer display can't change its density. As modern desktop displays usually have a PPI in the low 100s, the 600 x 900 pixel image will appear around 6" by 9" (mobile displays may be much higher). Of course, your web browser could display the image smaller if need be, but it will do so by averaging and eliminating pixels, not squeezing them to be physically smaller. This is why it's always important to keep your end goal in mind when working with images.
In summary:
• An image is defined by its pixel dimensions - # pixels tall by # pixels wide
• DPI/PPI determines the scale and pixel density at which image will be displayed
• What appears blurry from close up may look fine at a distance, so consider how an image will be seen
• Printers can produce a range of DPIs, while displays have fixed resolution
Whether you're a blogger dealing with an upload limit or are just trying to print a photo to hang on the wall, understanding DPI/PPI can go a long way. I hope these tips help you feel more in control of your images and how you share them with the world!
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
How big is the display on the iPhone 5s?
The display itself is exactly four inches. There is a 650 x 1136 mega pixel display with great resolution, which means a 326 ppi pixel density.
Sep 11, 2013 | Apple iPhone 5S
pixels per inch
Pixels per inch (PPI) is a measure of the sharpness
Apr 05, 2010 | Dell GX270 P4 256/40/48X/XPP/NONE...
Resolution of Stiil Photographs.
the resolutiion dpi has little to do with the camera, its more about printing/displaying - that is just the screen display resolution. you can change that to 300 PPI (DPI) in most imaging applications. the important thing is the pixels you have length and width so 1000 pixels x 1000 pixels is the key to this whats the max pixels of the camera - that would give you the resolution. now to print an image onto paper the acceoted standard for top quality is 300 PPI so 1000 pixels width divided by 300 pixels per inch ppi = 3.3 so you can print at 3.3 inches. Now you may even be able to get away with as low as 180 PPI on some prints and depending on how far away it will be viewed - so this needs to be played with. - can you reply here - with a comment and tell us 1) how many pixels you have 2) what image editing software you are using 3) how big you would like to print
Apr 17, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
90 people viewed this tip
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
