Tip & How-To about Miscellaneous
How to Manage Common Issue of Lexmark Printer: Tech Support
    Printer is one of the essential parts of our working life, it is not possible to do some of the task without printer in the daily life, Printer makes your documentation easy and fast, So Every organization that need the documentation so they need printer.
    Lexmark is one of the largest manufacturer companies of the printer and other hardware part of the computer. So This time we are going to describe that how you can deal with some of the common issue with you Lexmark printer, Although Lexmark printer are built with high-tech technology and modern designed, But some time some of the technical issue arise in the Lexmark printer-
    · Lexmark printer Driver is not Working
    · Lexmark printer Spooler Problem
    · Lexmark printer Cartridge Issue
    · Printer is showing some error code
    · Lexmark printer Failure Message
    · Lexmark Printer Not responding with the particular device
    · Printer is showing error with window 10
    · Lexmark Printer Unable to Print
    So these are some of the technical issue in the Lexmark printer, These are very common because when printer goes old day by day then these some of the issue arise in the Lexmark printer, So Here we are providing technical support and help to the Lexmark printer So Call Us any time to take advice and support online by toll free Lexmark Printer Technical Support Number, Where our technician team will help and suggest you better solution for all type of the technical issue in the printer.
Miscellaneous Logo
Epson stylus cx5500 printer problem
probably refers to empty cartridges
everything has a service life and it could be a possible part that is wearing out and needs replacing
you have 2 options --ignore it untl it stops performing
or get in a service technician
Oct 28, 2017 | Epson Stylus 2200 InkJet Photo Printer
i have lenovo m730 its cartlige over but but its not working after refil
Here the problem is the refill, while refilling the cartridge there is a hight possibility of getting the circuit damaged. If you use new cartridge the printer will work without any problem, refilled cartridge may spoil the entire printer. it is recommended to use New cartridge for better life of the printer.
At this point the old cartridge circuit seems to be broken, and the printer is not able to detect the cartridge.
check these
1. make sure there is no tape in front of the cartridge blocking the contacts,
2. Make sure the printer is set as default printer
3. Check for the cable, make sure all the cables are plugged in correct
4. Make sure the Power outlet is plugged in and it is turned on
5. try taking a copy of any document/ using the copy option (first button)
Mar 09, 2010 | Lenovo ThinkPad T61 Notebook
HP Photosmart Essential 2.5 does not work
unistall the software for the printer
you can download the unistaller from
http://revouninstaller.com/
reinstall the whole printer and the driver using the uninstaller
try and make a copy ,disconnect the power cable from the back of the printer and press power button for 20 to 30 sec
you can download the most recent driver for your printer from the following URL
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3645100&lc=en&cc=us&dlc=en&lang=en&cc=us
let us know if you get any more issues and we will be more than happy to help you again
thanks
regards
HAMID
Feb 20, 2010 | HP OfficeJet J4580 All-In-One Laser...
"parts inside your printer are at the end of there service life"
Go to indoreset.blogspot.com. Find SSc Utility or Adjusment program.
Jun 07, 2009 | Epson Stylus Photo R300 InkJet Printer
fatal error msi hp photosmart essential
Ok this is one of the critical issue in this printer when you try to uninstall it and the issue can be resolved in just 10 mins .
At the desktop screen you will see there is taskbar right click on that and select Task Manager in the task manager window select 'Processes Tab' and there You will find hpzstub select that and end that process >> exit out of the task manager window the installation will be completed automatically without any problem
....Happy Printing
Nov 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
54 people viewed this tip
Top Miscellaneous Experts
Leslie Rowe
Level 1 Expert
Steven Wander
Steven Wander
Scott Tumath
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
