Tip & How-To about KitchenAid KSM150PS Artisan Series Stand Mixer
Home Stand Mixers Buying Guidebook
After spending the last winter holiday preparing cookies, cakes, and many others., all by your individual, you probably got convinced you will want to buy a kitchen stay mixer. This convenient home gadget makes mixing mixture, whipping egg whites along with kneading dough almost straightforward.
So, if last Christmas you've gotten the feeling that been recently a multitasking person can be impossible, you will discover the best way to actually be one after you get your new instrument. Just place your recipe ingredients in the bowl, turn the switch so you are ready for various other meal prep chores. You could be confident that the stand mixer will perform all the hard be right for you.
Since kitchen stand mixers are generally an investment that should last for countless years, it is important to realize how to select a model that could fit all your certain needs. For that go through our kitchen stand mixers acquiring guide:
Which model to pick?
Before picking a stay mixer model, it is important draw in consideration how often to you personally bake. If you merely bake occasionally, a more simple style without all the amazing features may be enough in your case. However, you don't ought to compromise in quality. Pay close attention to the size, power, potential and speed controls.
What size is plenty?
If your kitchen counter space is limited and you will need to go with smaller sizing stand mixer, make sure to go with a model that its overall weight is a least 10 kilos - lightweight kitchen stand mixers will usually move when faced which has a heavy dough.
For day-to-day employ traditional cooking, a mixer with a new 4 liters bowl along with 250 watts of power can complete the same task. But if you need to prepare pizza or bread dough using your stand mixer, a 5 liters serving capacity and 350 m of power is additional recommended.
How many speeds to watch out for? Kitchen stand mixers include a variety of speed options that let you from slowly knead bread to quickly whip egg whites. There are some models that include up to 15 distinct speeds. Since most home cooks do not require more than six speeds settings you'll be able to pick a model containing 6 or more rate settings.
Accessories and capabilities
Once you've decided which model to pick, it is time to make the decision with accessories and other features are crucial for you. For case in point, the type of beater attachment that provide your stand mixer is what determine how versatile your gadget might be.
Understanding the different popular features of kitchen stand mixers, will help you select just the appropriate kitchen stand mixer that is to be by your side every holiday season and others baking marathon of your own house.
The Best Kitchen Stand Mixers of 2017 Top 10 Reviews
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
My cuisinart electric cookie press ccp-10 doesn't press the cookie dough out.
Probably the motor is slipping threads on the drive shaft.
Dec 15, 2017 | Cuisinart Food Mixers
I only use my kitchenaid ULTRA POWER ksm90 on holidays. I started smelling smoke but see no burning. How do I fix this. Never dropped or mishandled.I was only making XMAS cookies .HELP ME PLEASE.
easiest best way to take care of that problem is to take it backto the store you should have a problem with itthat is a very good and reliable products
Feb 19, 2016 | KitchenAid Food Mixers
beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Apr 14, 2014 | Blakeslee DD-60 Stand Mixer
Kitchenaid says to run the machine on 'high' long enough to heat the gearbox well and then turn the machine upside down and let it cool.
What happens is when you don't use your mixer a lot the grease in the gearbox will separate into oil and thicker grease. Warming it and turning it upside down is supposed to mix all the grease together again and allow it to flow to the top of the gearbox.
Give it a try, check back if you get no satisfaction and we'll get you started on changing your grease.
Jan 01, 2011 | KitchenAid KSM103 Professional 5 Series...
75 people viewed this tip
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
