Tip & How-To about Miscellaneous
How The Language You Speak Alters Your World View
Now new research shows that they can also view the world in different ways depending on the specific language they are operating in. Just as regular exercise gives your body some biological benefits, mentally controlling two or more languages gives your brain cognitive benefits. For more visit: https://www.dammann.com.au/blog/language-speak-alters-world-view/
Miscellaneous Logo
I am doing research on PC vs Mac for unix programming. What are the differences? Which Platform would be preferred?
That was a rather open question.
As long as the language is standards-based, you should have no problem using the language on any platform where it's certified.
That said, anything related to utilising specific operating-system related features such as GUI are much different, except in Java. Since Java is the same output regardless of platform (but version-specific), you can run it on any platform with the correct version (usually the same or newer) Java Virtual Machine. As mentioned, Java programming is the same on almost any platform. Traditionally, Macs lagged way behind Windows as far as Java releases are concerned, but the lag a lot less now (a few months, sometimes less). Macs also are much more Java-friendly.
Non-Java GUI programming is, as mentioned, much different. Honestly, enough tools exist on both platforms to make GUI programming similar in experience, though much different in actual code.
C, C++ both program the same on either platform (again, GUI code will be platform-specific).
A giant plus to Mac programming is that you have access to all the UNIX-type stuff in a way which is a part of the OS, as opposed to on a PC, where it all needs to be added on. I love the Terminal app on OS X - nothing like it on PCs.
Finally, if you're backed by someone with money, the tools on PCs are a bit better than what OS X has to offer, but not substantially.
May 11, 2011 | InstallShield 10.5 Premier...
i can't get the backslash
Please change your keyboard layout to US
1. On the Language bar at the bottom of your screen (next to the clock), click the Input language button, and then select an input language.
Click the Keyboard layout button, and then select a keyboard layout.
Depending upon your Operating system follow the following steps to change the languages of your keyboard.
Instructions for Windows Vista
  1. Click Start and then Control Panel
  2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
  3. Open Clock, Language, and Region
  4. Click on Regional and Language Options.
  5. Click the Keyboards and Languages tab and then click Change keyboards.
  6. Under Installed services, click Add.
  7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
  8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
  9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Instructions for Windows XP
  2. In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
  3. Open Regional and Language Options.
  4. Click on the Languages tab.
  5. Under Text services and input languages, click on the Details button.
  7. In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
  8. Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
Nov 18, 2010 | Computers & Internet
how to change computer language
1. Click on the menu button on the taskbar.
2. Click on the control panel icon
3. Now I need to know the way you use your Control Panel
4. If your control panel has a blue background. You are using Category view
5. If it has a white background ( This is the same as opening a folder on your computer ) then you are having classic view
Now. The change of language depends on your view ( Either classic or Category ( Explained above ))
Classic view
Classic view will make it much easier for you to change the language.
1. Once control panel is opened. You should find a folder named "Regional and language options"
2. Double click on this icon.
3. A window will pop-up
4. Then there you can change the language. ( to change it is the first thing on that window )
5. Default is English (UNITED STATES)
Category view
1. Fire up your control panel
2. Click on the icon " Date, time, language and Regional Options "
3. Then down under the category "or pick a control panel icon "
4. click on "Regional and language options "
5. A window will pop- up
5. Change the language ( To change the language it is the first things that appears on that screen
6. Default is english (UNITED STATES)
NOTE:- To change back ( since it will be in a different language, remember the placing of the icons.
Jul 14, 2010 | HP Pavilion dv6000z Notebook
IBM Laptop/PC Best Trouble shooting software
Your question is general. What are you troubleshooting? There's no such software that when you run it, it will fix your whole PC/Laptop. It still depends on what the problem is, specifically. The best way to fix computers when it comes to software problems is uninstalling and reinstalling the specific program that creates the problem, or better yet, re-format your whole computer and just reinstall your Operating System. Some problems are caused by virus which can be solved by spywares and anti-virus softwares, really depends.
Aug 29, 2006 | IBM ThinkPad T42 Notebook
127 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
