Tip & How-To about Music
How to install music app
  1. Make sure your iPhone is logged out of the Music app. ...
  2. Connect your iPhone or iPad to your Mac via USB charging cable.
  3. Open iTunes on your Mac (if it doesn't open automatically). You can also visit sites that feature music apps such as www.fameafrica.tv
  4. Click on the Device button in the toolbar to the left of the My Music tab.
  5. Select the Music tab in the sidebar.
  6. Check the Sync Music box.
Music Logo
how do I put sounds on the pad
What sounds?
Music can be placed, using iTunes on a PC or MAC. If you have installed iTunes on the computer (it is a free program), you can rip any CD on the computer, and it can add the music to your iPad.
For podcats, you can get audio for free on the net. and there are many more possibilities to get things on the iPad (Mini) for free. Don't forget to use the volume contral, as soon as you want to play anything. Knobs on the side, or swipe up, to open the control panel and swipe the volume to the right.
Oct 01, 2014 | Alesis CONTROL PAD MIDI CONTROLLER...
I only have a vintage Peavey XR600B and I want to connect and ipod and ipad up to it so I can play music. Can I do this or do I need special cables?
Sure you can, but that mixer amp is a mono amp instead of stereo. Head for radio shack and get an 1/8" stereo male phone jack to 1/4" female mono adaptor. Plug the adaper into the headphone output of your device. Then run a shielded cable with 1/4" mono phone plugs on both ends (like an electric guitar would use) from the device to one of the channels on the Peavey. Bring the volume up on both the channel and master on the amp up maybe 1/3 the way. Play a track on your device and adjust the devices out put as high as it will go with out distorting the channel input. Then adjust the amp's channel and main output as you would normally to get the final volume you need.
Jun 28, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
Zoom h4n won't connect as mic via USB
What I figured out - simple. Plug your usb cable all the way in. That's it. Did I guess it? ;)
Apr 12, 2012 | Zoom H4 Handy Recorder
What exactly do I need to connect a Mackie 402-VLZ3 to a Macbook Pro ? Where can I buy the cables? Thanks!
The internal audio systems in the PC's are inadequate for high quality work. You should get an external audio system that attaches via firewire or USB to your MAC. Then use balanced cables from the mixer to this audio interface. There are MANY different audio interfaces... Search the music equipment suppliers in the "recording" section of their catalog...
Feb 10, 2011 | Mackie 1202vlz3 12 Channel Mixer
67 people viewed this tip
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
