Tip & How-To about Kitchen Ranges
Electrolux Range E 15 Error
I have an Electrolux slide-in Range/Oven combo. Model # EW30ES65GSE.
I had the ubiquitous E 15 error, which renders the touch controls (and therefore the range and oven) entirely useless. I tried two things to resolve, per Electrolux customer service: 1. turned the circuit breaker to the stove off, and leave off for 10 minutes, then turn back on. If you are very lucky, this may be a one-time "false error" and you might be OK. 2. if you can get to the "user preference" option, try to reset the stove to factory default. Unlikely this will work, but worth a try.
In my case, neither worked, but if you can time it properly, between "alarm beeps", sometimes you may be able to turn a stove burner on, and then the E 15 may errors/beeping, may go away, but may happen again, seemingly at random.
If you are out of warranty, Electrolux customer service will advise you that you should have purchased an extended warranty, which is ridiculous considering how much this range cost initially.
Customer Service indicated there is no way to diagnose which part is bad, so they will sell you two different boards that will hopefully address the problem. These parts are a control board and a relay board. The control board is the digital pad that mounts in the front of the range, and the relay board mounts behind the rear cover, in the upper right. Parts numbers are: 316443916 and 316576612, respectively. After replacing BOTH parts, that seemed to fix it. Note - the Electrolux parts have a tremendous mark-up. You might be able to obtain these parts for less $ elsewhere - certainly worth a try.
There are literally hundreds of posting regarding this E 15 error, and it seems more "popular" in the inductive cook top model (mine is non-inductive). If the range is over 1 year old, forget about Electrolux standing behind their products. I firmly believe this is a manufacturing error (cheap boards) and Electrolux refuses to stand behind their products.
In my experience Bosch does a tremendous job in customer support, perhaps top in the industry and Electrolux is at the VERY BOTTOM. As consumers, we all have a choice on what to purchase, and based on this Electrolux experience, I WILL NEVER PURCHASE AN ELECTROLUX PRODUCT AGAIN.
Kitchen Ranges Logo
my stove top does not respond to the touch
Good Morning Kenneth Kozoway, thank you for your inquiry!
I see that you have explained the stove top on your Electrolux range is not responding to touch and the oven controls are working properly. From what you have described it sounds like a possible issue with your control panel or sensor. I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. If that does not help correct the issue I would recommend having a professional technician come and perform a proper diagnosis for repair. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux 30" Self-Cleaning Slide-In...
how to fix error code 15
Hi friend, thank you for your inquiry!
Based off your post your Frigidaire range is providing you an "E15" error code. "E15" stands for a signal loss between the oven relay and EOC (Electronic Oven Control) I would perform a reset on your appliance. You can do that by disconnecting power to your range by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not correct the issue it could mean that your oven relay board or electronic oven control may need to be replaced. If that is the case I would suggest seeking assistance from a professional to avoid any unnecessary part purchases. -Matt
Sep 28, 2014 | Electrolux EW30ES65GS 30" Slide-in...
e15 error code
You have an error between the control board and electronic oven control. 1. Test the harness and connections from EOC connector P16 to Oven Relay Board J2. 2. Replace the Oven Relay Board. 3. Replace the EOC.
Aug 11, 2012 | Electrolux EW30ES65GS 30" Slide-in...
my oven is beeping on an E11 error code on my electrolux range. How do I stop this?
E11 indicates a communication error where a technician needs to diagnose the control board.
Jul 23, 2012 | Electrolux EW30ES65GS 30" Slide-in...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
162 people viewed this tip
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
