Tip & How-To about Samsung SGH-x475
Format your Nokia Phone
Here's how to format your phone
but some nokia phone only mostly symbian.
backup first everything.... :-)
phone must be OFF
then HOLD simultaneously
the three keys.
(call button)+(*)+(3)
then Power ON
wait till formating apears
then unHOLD
there you go Dudes hope you'll understand... peace ;-)
Samsung SGH-x475 Logo
noki e71 mobil unlock factory code
This is not same as factory settings found on phone settings. As name suggests it's a hard reset & very hard to execute with two hands:).
Note: This will delete everything on your phone memory. So if you have access to phone (Phone is not locked), Please backup data. And also make sure phone battery is full before performing hard reset. tjosm.com is not responsible for any data lose.
Ensuring phone is turned off, press & hold below 3 keys simultaneously,
  • For classic style phones
1Call key + Asterisk key (*) + Number Three (3)
  • For full Touch Phones
1Call key + End key + Camera-capture key
  • For Touch Phones with Qwerty keyboard
1LEFT SHIFT key + SPACEBAR key + BACK key
  • For SYMBIAN^3 phones (Nokia N8, C7, E7, C6-01, X7, E6)
1Volume Down Key + Camera Key + Menu Key
Ensuring that above keys are being pressed, Press & hold Power button until you see message "Formatting" on your screen. Release all keys & wait for formatting to be completed. Once completed, Phone is like just out of the box. Not physically though. Most importantly, your security code is now reset to default. Which means 12345
Feb 26, 2013 | Nokia E71 Smartphone
i forgot my nokia c1-01 mobile security code.now how
Feb 26, 2013 | Nokia C101 Cell Phone
i forget my security lock of nokia X2-01 imei- 356996/04/476315/8 how i open it
Feb 26, 2013 | Cell Phones
how to format nokia 6101
First thing first, not all the Symbian phones can be formatted by the so called "Formatting codes" (Will not work in Series40 phones like Nokia 6300, 7210, 5130 etc and the older Nokia Generic OS based phones like Nokia 1600, 2600 etc). These phones can only be formatted through flashing (Re-installing) their OS software (Firmware) via data cable and computer. Only Symbian S60 (And a few of other series) based mobiles have built-in support for the format codes. So format codes will work in all Symbian^1 (S60 1st, 2nd, 3rd, 5th edition) phones like Nokia 3650, 3660, 6600, 6630, 6680, 6681, 3230, 7610, 6670, 3250, N70, N72, N73, N75, N76, N77, N78, N79, N80, N81, N82, N83, N85, N86, N90, N91, N92, N93, N95, N96, N97, 5800 and other touchscreen phones plus the newer Symbian^3 phones (Nokia N8, C7 and E7 etc). Now lets begin with formatting process: There are two methods to format the phone depending upon the situation: A. When the phone is in working condition:
Just press any of the following two codes at standby screen *#7780# or
*#7370#
Phone will ask for confirmation and security code (Default security code is 12345), enter it and bingo everything in phone memory will be erased and phone will be back to factory settings.
B.
Hard Reset - When the phone is not starting-up (i.e. not working after white screen or Nokia Logo screen)
- then follow these steps: 1. Switch-off the phone
2. Press and hold following three keys simultaneously (Remember "All the three keys" simultaneously):
Green Key (OK or Number Dialing key), Star key (*) and Three key (3 number key)
3. While still holding the above three keys, press the power on/off key to switch-on the phone.
Still continue holding the three keys until the "formatting" screen appears. Now you can release the keys, confirm if asked and then wait for the format to complete. Now the phone will be restored to its original factory settings. Read HERE to know about hard resetting Nokia N97, 5800, 5230, 5530 and other touchscreen S60 5th edition phones.The above format will reset the phone but most probably will not clear the operator's lock codes.
Follow the instructions below to format Nokia 9300/9500 (Communicators)
1. Restart the phone
2. Just when the "NOKIA" logo appears on screen, PRESS AND HOLD following three keys simultaneously:
Shift (Up Arrow key) + Ctrl + F
3. KEEP HOLDING them until phone prompts you whether or not to proceed with format. If however the format menu does not appear this way then remove and re-insert the battery and try again. If the phone display remains black after inserting the battery, press power button on the phone side while keeping the cover open and repeat the above procedure. After formatting, phone will reboot. If the screen remains white after reboot, press power button on the phone side while keeping the cover open.
NOTE: Before formatting the phone, make sure -
1. That you backup all your phone data to either computer or memory card as formatting will erase everything in phone memory.
2. That the phone's battery is charged fully or is plugged in AC power because if unfortunately, the phone runs out of battery during format, then the phone may get permanently damaged and irreparable.
3. If your phone is infected with a virus (Only applies to 1st and 2nd edition phones) then also format the memory card and scan it with a good computer antivirus like Avast.
I hope that the above instructions will help the needy.
Oct 06, 2011 | Nokia 6101 Cellular Phone
2,160 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
