Tip & How-To about GE Home Security
GE RANDOM VACATION TIMER GE5111N-71D also known as GE5111N
VERY straight forward setup. SET the Dial to the correct DAY of the week and TIME. This timer is PRESET at the factory and you can NOT adjust any other ON/OFF settings yourself!
"Pre-Set" mostly for evening and later evening times or hours "ON/OFF". These times CHANGE from evening to evening and again, ALL settings are made by GE! ALL ON/OFF cycles change from evening-to-evening and day-to-day.
120VAC
operation.
SWITCHES: 1,875 WATTS MAXIMUM!
1,250 WATTS if you connect INCANDESCENT LAMPS!
I hunted and hunted for the specs on this Timer, but found none. I finally purchased two and read the tiny manual. I set one up in the kitchen to TEST with a 50 Watt lamp and it works GREAT... I just don't know WHEN it will cycle next, but I guess that's the mission and point of these spiffy timers!
SOGLAD
Home Security Logo
how does that thermostat work that sets the time for the defrost period?
Most domestic refrigerator timers are factory set and cannot be adjusted. The timer runs for a preset time in cooling and a preset time in defrost. Timer types are model-specific. Here is a video of a technician showing and explaining the testing of a defrost timer.
https://www.youtube.com/watch?v=sylSVZKGB9I
Feb 08, 2015 | Refrigerators
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
What is a minimum timer setup
Question is not clear, timer is not identified.
Add a comment with in-focus photo of timer posted on flickr.
Minimum on-off time for digital timers is usually 1 minute.
Minimum on-off time for plug-in-type 24-hour analog timers is 1/4 hour or 1/2 hour depending on width of tripper-pin-segment.
Minimum on-off time for plug-in-type 7-day analog timer is usually 3 hours.
Plug-in vacation timers are set for random on-off and cannot be set.
Minimum on-off time for box timers with 24 hour dial and wide tripper is 1 to 1-1/2 hours
Minimum on-off time for box timers with 24 hour dial and narrow tripper is 1/4 hour.
Minimum on-off time for box timers with 7-day dial is usually 3 hours
Open following link for information how to set analog timers
http://waterheatertimer.org/How-to-set-timers.html
Jun 12, 2011 | Intermatic 10 Amp Mechanical Indoor Timer
need instruction for setting time of day
You posted under Paragon 1015 timer.
Open following link to identify timer and download manual.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
Timers are 24 hour, but some have 7-day capability:
Manual says: to set 7-day grasp large 24 hour dial and rotate either direction until correct day of the week appears below Day Set red dot and 12 noon on large 24 hour dial is below red pointer.
To set 24 hour, grasp large 24 hour dial and rotate either direction until correct time appears below red pointer.
Red pointer is stationary at 6:00 position.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 14, 2011 | Paragon 1015-00RS Indoor Multi Operation...
I have 2 intermatic lamp & appliance programmable timers. On the package the model number says: TN811C and on the timer itself says: TN811. Anyways I have read the instructions and I can't figure out how to work the timer. What's the off/on dial for on the top of the timer. Do the things need to be pushed up to be on or pushed down to be on? I need help. Thanks
1. To Set Program:
Pull up one tripper
between hour marks
on the 24-hour dial
for each 1/2 hour of
ON time desired. For
example, if timer is to
be ON between 12-2
PM, all four trippers
between those times
must be pulled up.
2. To set time
of day: turn dial
clockwise with the
arrow head pointed
to the correct time.
The dark area
denotes PM and
the white area
denotes AM.
Straight out of the manual. Pull up trippers for all of the time that you want the device to run.
Rotate the time of day dial in the direction of the arrows.
The off/on dial will override the timer until it comes around to the on time again then the timer will control.
Good luck.
Gary
Dec 10, 2010 | Intermatic Hardware & Accessories
518 people viewed this tip
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
