Tip & How-To about Garden
Misting Systems of Greenhouses
Misting systems of greenhouses supply and maintain adequate humidity, filter the air, reduce the effects of smells and also minimize dirt pollution. Managed, intermittent misting decreases the dampness lost by plants in the greenhouse while staying clear of condensation on the leaves, avoiding the development of mold and mildew as well as fungi. However, continuous misting is a waste of water. This method eventually drains pipes important nutrients from the plants' fallen leaves as well as decreases the dirt temperature level, avoiding proper root growth.
Ecological variables such as the quantity of shading, air flow and also day-to-day weather variation throughout warmer seasons identify what degree of moisture the greenhouse must achieve to maintain offer problems. Avoiding the plants from overheating in a greenhouse is as important as safeguarding them versus frost damage; both rapidly eliminate them. Nevertheless, excessive humidity results in rot as well as disease, so plants need to be sprinkled just as essential.
Centrifugal force is made use of to feed an adjustable flow of water through a high-speed follower, creating a light mist. The water beads vaporize instantly in the air. The natural circulation produced by the fan stops awesome air from working out around the plants and also warm air from being shed too quickly. This maintains regular temperatures while spreading out the mist equally inside the greenhouse.
A high-pressure pump is attached to a spray nozzle that is particularly made to generate beads of water small adequate to evaporate rapidly. Upright risers raise the nozzles over the plants so that the water can vaporize without leaving recurring moisture on plants as well as various other surface areas. Some high-pressure systems need established by an expert installment company guaranteeing that their complicated filtering system, feed lines, distribution pipelines and assorted fittings are connected correctly.
Greenhouse misting system mechanisms keep track of humidity and dissipation rate, interacting with thermostats as well as timers in controlling the internal climate of the greenhouse. Numerous systems utilize two flexible time clocks. The very first is a 24-hour clock that transforms the system off at night as well as on in the morning. The 2nd is a timing clock that manages the length of time each cycle lasts, making the cycles adaptable to fluctuations in weather conditions.
Home Page
Garden Logo
My African Violets have a mildew looking leaf and flowers which are blotchy with mildew. How do I get my plants healthy again?
Good cultural practices are a primary deterrent to powdery mildew. Place plants to allow for plenty of air circulation between plants and adequate sunlight. Also place them in an area where the temperature does not fluctuate more than 10 degrees Fahrenheit, especially from day to night, as the change increases humidity around the plant, which encourages the development of powdery mildew. A fan near the plants can stir the air to both improve air circulation and keep humidity down around the plant. Dispose of any foliage, flowers or buds with signs of powdery mildew and keep the plant isolated and in ideal conditions.
Chemical Powdery Mildew Treatment When infected plants do not respond to cultural controls, chemical controls can be effective. Both the African Violet Society of America and commercial African violet nursery Optimara recommend misting the air immediately around affected plants with a household antibacterial spray, such as Lysol. Do not direct the spray on the plant itself because it is extremely cold and could damage the plant. Spraying with organic neem oil, jojoba oil or a mixture of 1 teaspoon of baking soda in 1 quart of water is effective on mild to moderate powdery mildew. Synthetic fungicides are usually only effective before the powdery mildew is evident.
Aug 07, 2017 | Garden
WHO DOES ELECTRICITY CAUSE POLLUTION?
Electricity itself does not cause pollution - the production of electricity is what causes pollution. To produce electricity on a large scale, power plants use rotating turbines, which make electricity with the help of a generator. To spin the turbines in a traditional power plant, the fuel must be burned.
The burning of coal and oil in fossil-fuel power plants creates greenhouse gas emissions like carbon dioxide, along with other pollutants. Nuclear power plants have much lower direct emissions, but the process chain of mining and processing uranium and building and maintaining nuclear plants causes pollution.
Jan 04, 2017 | Green Living
Haier window ac constant red light? No label next to red light. Turns on and off fine. Cleaned filter, no change. couple years old. Still cools down the room but not as cold as it used to. Help?
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Here's a great YouTube video explaining how to properly clean a window AC. How to Clean Window Air Conditioner
AC units should be cleaned every year (including the whole house units), to maintain their ability to cool efficiently.
Aug 13, 2016 | Haier Heating & Cooling
Fan runs but compressor does not come on or stay on long enough to reduce desired humidity level
Three things can cause the problem you're having:
1. A dirty or clogged air intake filter.
2. The humidity extraction level (percentage) is set to high. Lower it to 35%. Or minimal if you don't have an LED display.
3. Not enough clear air space around the unit. Maintain a minimum of 12" clear space around the entire unit.
Number 1, should become a part of a every two week routine maintenance program.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Dehumidifiers
72 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
