Tip & How-To about Apple iPhone Smartphone
How to disassemble and reorganize iPhone 7
It is good for you to know how to disassemble and reorganize your iPhone 7, just in case. However, it is need many of phone repair tools to finish this engineering. Fortunately, now is the internet age, you can buy anything through the internet. Now we list the phone repair tools we need, they are phone opening tool, SIM card eject pin, tweezers, knife set and different types of the screwdriver. If you want to quickly find high-quality tools ,maybe you can try Vipprogrammer.
when you prepared all of phone repair tools you needed, then we can start.
1. Turn off your iPhone 7.
2. Pop up the Nano-SIM card tray.
3. Using screwdriver to unload two Pentalobe screws beside the lightning connector.
4. Carefully disassemble the cable and liberate the iPhone 7 display assembly from the phone.
5. Take out the stereo-enabling speaker and teardown the Front-Facing Camera Cable Assembly of iPhone 7.
6. Carefully extract the battery.
7. Pry the rear-facing camera out of the chassis and digging the iPhone 7 logic board out of the rear case.
8. Know down the iPhone 7 loudspeaker.
Finally, remove the last component which contains the power and volume button switches, LED flash, a microphone, and the ring / silent switch. When iPhone 7 power and volume buttons are nuzzled securely in the rear, just defying conventional removal.
The related link:
  • Original universal programmers Online Shopping Store from China
Electronics Accessories for Automotives chip programmers
Apple iPhone Smartphone Logo
Rplacment Battery cover for. Bc92xlt
When you replace the battery, you might need some phone opening tools, disassembly tools, replace tools, you can choose Vip Fix Shop Team. http://www.vipfixphone.com/phone-disassembly-tool-repair-87_135/vipfix-13-in-1-iphone-repair-opening-tool-kit-pry-tool-for-cell-phone-fixphone-3741.htm
Dec 15, 2017 | Cell Phones
can not get to the seeting schree n on the I phone number 7 help
If you want to know the iphone 7 repair tools, I will introduce you a good website, vipprogrammer.com
May 08, 2017 | Cell Phones
How to fix iPhone 4s power button without taking it apart
You could try casting a magic spell on it?
you haven't said what is wrong with it? I doubt you can fix anything on an iPhone without disassembly. The best people to advise you are the guys in the malls that repair cracked screens, sell cases and phone cards.
Lots of Power Button fixes here.
fix iPhone 4s power button Google Search
Jan 18, 2017 | Apple iPhone 4S
how to unlock icloud activated iphone 6s
FREE VERSION ENJOY !
Unlock iCloud iPhone 7,iPhone 6S, iPhone 5S, iPhone 6S+, iPhone 7 plus
http://howtounlockicloud.com/
Unlock iCloud iPhone 7, iPhone 6S, iPhone 5S, iPhone 6S+, iPhone 7 plus
All iOS iPhone 4S iPhone 5 iPhone 5S iPhone 6 iPhone 6 plus iPhone 6S iPhone 6S plus iPhone 7 iPhone 7S All iPad's
Remove iCloud activation lock, bypass iCloud lock
First method Free
For using this method to bypass iCloud by yourself you will need:
iTunes installed
Notepad++
Total Commander
iCloudSyncKey software
For decoding the icloud lock you must have a locked iPhone device and a neverlocked device same model only for unlocking time not for your self. With the neverlocked iPhone connect the device to iTunes and make a sync of a picture , melody or any file, after that you dont need any more the neverlocked device. The ideea is that the iTunes needs to be used with the same model like the icloud locked device before bypass iCloud.
First of all after you have all programs ready make sure that the iTunes is not running then open total commander go in iTunes install folder directory look there for iTunesCore.dll and open this file with notepad++. After this search in notepad++ file the "Unactivated" keyword, the search may be repeated if notepad++ does not find the first time the keyword. When the "Unactivated" is found change from "Unactivated" in "Unbctivated" the "a" character to "b". After this operation save the file and close notepad++.
PAID VERSION
Unlock iCloud iPhone 6S, iPhone 5S, iPhone 7, iPhone 6S+, iPhone plus
Download from:
http://unlock-icloud.com
Unlock and remove iCloud for:
All iOS
iPhone 7
iPhone 5S
iPhone 6
iPhone 6 plus
iPhone 6S
iPhone 6S plus
All iPad's
Real and working by software, work on all Apple iPhones
Trusted solution work 100% i recommand it's verified!
The software is easy to use and the support team from unlock-icloud.com offer good technical support with team viewer and video for unlock icloud and iphone repair solutions. The signal work excelent after i have used this software. The software is clean no viruses or other bad things like other software from internet.
With this software i managed to repair my iPhone 6 iCloud errors and bypass activation lock. It's a realy gsm repair tool.
Jan 17, 2016 | Apple iPhone Cell Phones
142 people viewed this tip
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
