Tip & How-To about Miscellaneous
Sticky or binding power windows.
Are your automobile's power windows getting sluggish or binding? An inexpensive repair is with WD40 Silicone Spray. Not plain WD40 because that will quickly wash away. You must use the WD40 Silicone. The rubber in the track drys out and begins to bind. The silicone spray lubricates the rubber and resists water for a long time.
Lower your window(s) and spray front and rear tracks all the way from the top to the bottom. Wait a few moments then do it again. Now close and open the window(s). It should be operating correctly. If not, do it one more time making sure you have sprayed the entire track.
Miscellaneous Logo
2000 Chrysler town and country. r/s front door window it keeps popping out of lock on the window regulator only on the front half the rear does not pop out
Sounds like window is binding on the rear as it rises. Try black silicone sealant on the bottom of the glass where it fits into the regulator then inspect the rubber channels for damage. If ok then spray channels with silicone oil spray like WD40.
May 22, 2017 | Chrysler Town and Country Cars & Trucks
why throttle hard to turn?
Throttle system, as well as other controls require periodic service.
Lubing your throttle with WD40 or similar silicone spray, at the handle, and working some down the cable, and moving parts at the carb. Follow the cable, twist the grip to see what all moves at the carb and spray it up. If it still binds by all means removes and service or replace the cable. It's a dangerous problem.
Do up your clutch too.
Aug 11, 2014 | 2006 Honda VTX 1300 S
power window binding up when going up and down, replaced window guides that were broken, put cables on roller wheels, without window on works fine, put window on and binds up.
Try silicone spray on the rubber pieces and white lithium grease on the tracks it may help unless the regulator is being distorted when the window is on and thus not aligned properly.
Apr 02, 2010 | 2000 Pontiac Grand Am GT
windows go down slow and have to be pulled back up?
have u lubed the window channels with spray silicone? it really gets the windows working freely again.
Mar 30, 2009 | 1985 Ford Thunderbird
power window tips forward and binds
one or more of your rollers in the regulator are broken.needs new regulator or roller kits.
Nov 08, 2008 | 2000 Chevrolet Tracker
53 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
