Tip & How-To about Cell Phones
Repalce the iPhone Battery Adhesive Strips guide
With the correct method as followimg, you can successfully replace Battery Adhesive Strips of any types iPhone. Everytime you unload the battery by iPhone opening tools, these strips must be replaced. It's very easy to injure the strips if you are not use correctly. Therefore, the best way is you have backup strips when you are the first time to replace this strips .you can use your fingers to remove the strips or you can use the tweezers of phone repair tools.
The larger iPhone "Plus" models use three strips instead of two, but the procedure is the same.
When you put your battery out, you can carry out the remover of the iPhone Battery Adhesive strips.
1. Remove the small plastic film covering the flat ends of the adhesive strips. Catch the large blue membrane backing instead and shell it back slightly to expose a small amount of adhesive near the flat end of the strips.
2. Put the battery upside down (battery connector on the right) ,carefully lever the exposed parts of the adhesive strips along the lower edge of the front of the battery, and press them lightly into place.
3. Peel off the large blue film covering the strips on the flat surface.
4. Softly roll the adhesive strips over the bottom edge of the battery toward the back by using your fingertip.
5. Lay the strips down flat and let them stick to the back of the battery.
6. In order to fully exposing the adhesive strips,you should peel away the remaining piece of film.
7. With the strips facing down, align the top edge of the battery into your iPhone.
Finally: When the battery is correctly positioned, lay it down in the iPhone and press it firmly into place, allowing the adhesive strips to stick to the rear case.And then ,you can put the battery back on your iPhone and make it re-work.
The related link:
iPhone 5S 6 6S 7 7P battery Anti static built in heat sink sticker
Cell Phones Logo
how do I access battery on IPhone 4S?
Why do you want to do this? You void all guarantees, and Apple won't service it again. Better to take it to Apple store for assistance.
Oct 06, 2015 | Apple Iphone 4s I Phone 4 S Factory...
iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
Feb 25, 2013 | Apple iPhone4 4G iPhone 4
my iphone battery died and wont come on after charging for an hour
replace your battery dude. Battery cannot be repaired!!
May 07, 2010 | Apple iPhone Smartphone
dash board mount
you can buy a heavy duty double adhesive tape, or use a permanent adhesive, or mighty bond onto your dash board since the gps is still removable
Oct 06, 2008 | Garmin StreetPilot C330 GPS Receiver
100 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
