Tip & How-To about Apple MacBook Pro Notebook
Steps To Troubleshoot The Error “MacBook Won't Charge”
Steps To Troubleshoot The Error "MacBook Won't Charge"
Unable to charge the MacBook can often be really frustrating for users. After all, it's considered as one of the most beneficial devices ever. A user can unplug it from the mains and can easily use it anywhere anytime. So, that's the only thing which will make sense if it holds a charging point. In this blog, our MacBook tech support experts are going to make you aware of how to troubleshoot the error when it say that "the Macbook won't charge".
Steps to troubleshoot the error "MacBook won't charge"
Step1: Check for all the basic features
    ·Check whether the MacBook is plugged in? Is the MagSafe connection accurately plugged in to the laptop?
    ·Perform a deep check for the Apple adaptor whether it is connected together or not? Each Apple laptop adaptor will comes in two parts, the first one will be a square adaptor and the second one will be a removable plug (or lead) that will have full capability to connect to the wall. Pull up both the parts and then put them back together.
    ·Perform a check whether you have plugged into a wall socket or not? Is the socket accurately turned on? Have you ever given a try to a different wall socket?
    ·What does the Apple adaptor actually appears to be? Perform a check for whether it in pristine condition or has it got any tears in the cable?
    ·Check carefully for the MagSafe connection on the Apple laptop for any dust. By doing this will surely prevent the MagSafe connector from making a clean connection to the Mac device and will stop users from charging it up accurately.
    Step2; Check for all the settings
      ·Open up the "System Preferences" option and choose the "Settings > Energy Saver" icon.
      perform a check for that the Computer Sleep as well as Display Sleep slider option.
      ·If they appear, then carefully click on the "Default" button to reset it.
      Step3: Apple's solutions
      At last, the Apple device has three solutions for this error that are described by MacBook technical support professional team members and they are as follows:
      • Resetting of the battery
      If a user is having an older Apple laptop with a benefit of removable battery then one should definitely remove it and re-insert to make sure it's completely installed.
      • Reseting the SMC:
      Resetting the SMC which will help the proper functioning of the battery and power related problems.
      • Get the Mac serviced:
      If resetting of the SMC doesn't work at all then the Apple recommends you to take the Mac to any nearby Apple Store.
      Well, these are few solutions for the above MacBook issue. If still in confusion then do try us at MacBook customer support Toll-Free 1-800-213-8289 number which is absolutely a toll-free service available for users 24*7 hours a day. We solve all types of Mac Book related issues by applying the best available solutions in the market.
Apple MacBook Pro Notebook Logo
macbook won't charge
Your battery is probably not working anymore. Go to an apple store and ask for the repair.
Oct 24, 2012 | Apple MacBook Laptop Computer Mac...
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
i have a macbook whose battery suddenly stopped working. the icon shows "X"; when I check the battery status, it shows "battery not installed". I have to have it plugged-in in order to work. until this happend I had been callibrating the battery regularly - this happened after the last callibration. what is wrong?
Most likely your battery failed during the calibration. Calibrating the battery is not something that you really need to do very often -- if at all. Most likely the deep power cycles you were doing with the calibration damaged the battery.
You'll have to to take the Macbook in to replace the battery -- depending on the model, they will just give you a replacement battery to purchase or you will have to have them replace the battery.
When you get your Macbook back, don't worry about calibrating the battery and just charge as usual.
Oct 25, 2011 | Apple MacBook Mac Notebook
My phone won't charge and is about to die. When I put it on the charge is says "Unable to charge. Non supported battery." I've tried using the air in a can stuff on the ports but that didn't fix it. What do I do??
You may have a hardware problem. It's very common for the charging port in a cell phone to become damaged somehow, which can cause this error. Other possibilities is a damaged battery or damaged power cord. Your best bet is to bring the phone to your carrier's nearest store and have them check it out for you. If it's the battery or the cord, a simple replacement is cheap and quick, but if there's a problem with the phone itself, you'll need to get a new one.
Jun 10, 2011 | Samsung Glyde SCH-u940 Cellular Phone
My computer won't charge! The problem is that where i plug in the charging adapter that "little hole" is loose and won't keep the adapter in, ultimately not letting it charge
This is really a physical damage to the slot for the plug.
There are some tweaks that you might try to keep it there, like pushing it and holding it with something, or use scotch tape or something similar, but ultimately it might affect the life of your battery.
There's really nothing substantial you can do other than changing the power adapter.
May 21, 2011 | Sony VAIO VGN-FW250J/H 16.4-Inch Laptop
86 people viewed this tip
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
