Tip & How-To about Eagle Tech ET-CS2PSU2-BK 2.5 SATA to USB enclosure with built-in USB cable Serial ATA, USB Drive Case
Attached USB Cable is Aging
If issues start occurring with the Eagle Consus ET-CS2PSU2-BK, it may be the attached USB cable. As the years passed the materials used for this attached cable are not aging well.
Before giving up on the installed 2.5 SATA HD in this case, attempt accessing it after moving the drive into another case or adapter. Once transferred, back up all data and run the drive through a series of test to verify its health and usability.
If the hard drive passes testing consider continued use, but regularly back-up or move any critical and/or unique data to another storage medium in case the original issues are more than an aging case.
If the Eagle Consus ET-CS2PSU2-BK does not show issues when a different drive is installed the same is true. Any data on the unit could become victim to the original or additional issues as the case ages.
Eagle Tech ET-CS2PSU2-BK 2.5 SATA to USB enclosure with built-in USB cable Serial ATA, USB Drive Case Logo
where is the drivers for eagle consus
Contact Eagle Tech USA support.
Their details are here:
https://support.eagletechusa.com/support/solutions/articles/5000637466-i-am-looking-for-product-warranty-and-or-technical-support
Drivers do not appear to be available on their website. The Consus has been around since 2008 and is discontinued.
Jan 19, 2015 | Eagle Technology SATA to eSATA enclosure...
Eagle Tech Consus Power adapter requirements
IF you have the Eagle Consus T ET-CSTSIU2-BK you must mean one of these (pictured). Check the exact model number of the units in the videos compared to the one you have. 3.5" hard drives need 0V (ground, earth), +5V and +12V which may be on the pins in a multipin connector in some external adapters or less commonly provided internally a single from dc or even ac supply. Further, your supply connector may not have multipins but be a multi-concentric ring type with matching socket (similar to a stereo plug). I suggest you try (discussing the matter with) Eagle support http://www.eagletechusa.com/customer-support/ or as outside chance buying another psu of the correct type from Amazon Newegg (who have sold out of this product) or ebay for example.
Dec 15, 2014 | Eagle Consus T ET-CSTSIU2-BK Metal 3.5'...
is a power cable, operator manual, and CD available
For manual see here
http://www.readbag.com/eagletechusa-download-manual-et-cstsiu2-bk
or here
http://www.manualslib.com/manual/710776/Eagle-Et-Csiu2j-Bk.html
All power cables are pre-attached to the psu I think (mains - psu - dc)
try eagle support: http://www.eagletechusa.com/customer-support/, they be able to provide CD (including manual) or the contents of the CD by download as well as other parts
Try ebay:
search for "Eagle Consus T ET-CSTSIU2-BK" before you decide on a purchase check parts/system compatibility. It may be more economical to replace unit then rhe parts. You might also various computer forums.
23.December.2014
Dec 10, 2013 | Eagle Consus T ET-CSTSIU2-BK Metal 3.5'...
i have a mac and a pc. my mac works with it but my pc won't. ?
mac and pc have different hard drive formats.
you have to use special software (mac drive ect) to read mac on pc
Aug 17, 2013 | Eagle Consus T ET-CSTSIU2-BK Metal 3.5'...
67 people viewed this tip
Top Eagle Computers & Internet Experts
Dennis Maeder
David Payne
David Payne
Mister Danger
Are you an Eagle Computer and Internet Expert? Answer questions, earn points and help others
