Tip & How-To about Bernina Sewing Machines
Bernina 830 Record Oil Diagram
Diagram of oil ports on a Bernina 830 Record sewing machine. Use only fresh, good quality sewing machine oil or Tri-Flow Synthetic Lube. One or two drops each oil port. Oil every 40 hours of use, every time before a new project is begun, every six months in storage. If the levers/dials begin to get sluggish, gently wiggle each and apply lube where metal rubs against metal (do not oil metal cams, belts, plastic). Directing heated air from a handheld hairdryer will help the penetrant to distribute quicker and loosen it.
Sewing Machines Logo
I have an old 281-3 machine that was given to me. It appears to work but I need to get oil for it. what kind do I buy? Thanks
sewing machine oil. go to your local sewing machine sales and get one that has a spout that can be extended.
Jul 07, 2017 | Sewing Machines
Where is the feed dog lever on my bernina record 830 sewing machine
On the Bernina 830 Record (older mechanical model), it is usually the very bottom knob on the right side (directly below the Stitch Length Lever). It should turn right or left about a quarter turn to switch between feed dogs up or down. If the knob is frozen, then it has seized due to old dried oil (a common occurrence with older mechanical machines that have not been serviced regularly). Stuck feed dogs, stitch selectors, buttonhole knobs, and the handwheel are some of the most frequent victims of seizure. However, with lots of patience, time, fresh good quality sewing machine oil or liquid Tri-Flow Synthetic Lube, elbow grease and a handheld hairdryer, these issues can usually be successfully addressed.
Wheel on right side that controls the needle up and down is very tight...
Jan 13, 2017 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
What kind of oil do I use for a bernina 830 record electronic
I agree with Tally Girl in using a good quality, preferably clear, light machine oil. Do NOT use 3-in-one or cooking oil as both will become "varnished" over time leading to a gummed up machine. I have been repairing both commercial ad domestic sewing machines for 45 years.
Jan 30, 2015 | Bernina Activa 130
78 people viewed this tip
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
