Tip & How-To about Samsung 8.4 in. Galaxy Tab Pro - 16GB SM-T320NZKAXAR Black
How to remove demo video from a Samsung Galaxy Tab Pro 8.4
You will have to do a factory data reset! I found when I bought this it kept playing a demo video every time I tried to close the screen. Go to settings, then general, then backup and reset. Turn off backup my data and automatic restore. Then touch on Factory Data Reset. You will have to agree to everything after it restarts but you can change these settings after you have reset your account info. This worked for me. You will loose your pics, data, and other things you have put on this device but if you transfer those dates to a SD card you can reinstall after resetting the tablet. This is the only way I found to get rid of the annoying demo video that comes with this thing.
Samsung 8.4 in. Galaxy Tab Pro - 16GB SM-T320NZKAXAR Black Logo
the word demo how do I remove it from a AKASO tablet it's in big red letters?
Factory reset it,
Power off completely
2. then hold down the volume down button
3. holding the button press the power on button.
4. if done properly you should have several android boot options
5. select "Factory data reset"
6. Done
Note: if the volume down did not work, try the Volume Up button
Oct 16, 2017 | AKASO Tablets & eReaders
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
I bought a used Samsung Galaxy Tab 4 (8.0) running on AAA Automobile Club towing system on it, I want its original android system back into it, where can I find that specific download? A link please!
Try a Hard Reset which clears everything off it and installs Android new. There are no Android download links.
  • Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8 ... www.verizonwireless.com > Samsung Galaxy Tab 4 (8.0) Before performing a hard reset, ... Home > Support > Samsung > Samsung Galaxy Tab 4 (8.0) > Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8.0) Ask Verizon:
  • How to Factory Reset the Galaxy Tab 4 - YouTube www.youtube.com/watch?v=nZBZYa4nZ18
    • BY ASKTHEANDROIDGUY
    • 3 MIN
    • 110K VIEWS
    2014-05-19 · Video embedded · How to Factory Reset the Galaxy Tab 4 Check Out Our New Website: http://www.RickytheAndroidGuy.com Like us on Facebook: ...
  • SAMSUNG T330 Galaxy Tab 4 8.0" - How to Hard Reset my ... www.hardreset.info/devices/samsung/samsung-t330-galaxy-tab-4-80 Hard Reset SAMSUNG T330 Galaxy Tab 4 8.0" First method: In order to switch off the tablet hold down the Power key for a short while. After that, press and hold ...
  • Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset ... solverbase.com/w/Samsung_Galaxy_Tab_4_8.0:_Hard_Reset_Factory_Reset Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset. From ... How to make a Hard Reset (Factory Reset & Data Wipe) on Samsung Galaxy Tab 4 8.0"? Samsung ...
  • Samsung Galaxy Tab 4: Steps For Hard Reset - Technipages www.technipages.com/galaxy-tab-4-hard-reset How to perform a factory hard reset on the Samsung Galaxy Tab 4 tablet. Technipages Smart phone, gadget and computer tips. ... Samsung Galaxy Tab 4: Steps For Hard Reset.
  • https://www.android.com/tablets
    May 23, 2016 | Samsung Tablets & eReaders
    I forgot my password for my trio stealth g5 7 can u help me reset it or something?
    I Forgot My Password To Unlock To My Tablet? Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
    1. Tap on Settings.
    2. Tap on Backup and Reset on the left hand column.
    3. Tap on Factory Data Reset on right hand side.
    4. Tap on Erase SD Card. (optional)
    5. Tap on Reset Tablet and Erase Everything.
    Or
    Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
    1. Make sure tablet is powered off.
    2. Hold down Volume + button and Power button at same time.
    3. When screen comes on let go of Power button.
    4. When the large Android shows on screen let go of Volume + button.
    5. Use Volume - button to scroll to Wipe Data/ Factory Reset
    6. Tap Power button to select.
    7. Use Volume - button to scroll to Yes.
    8. Tap Power button to select.
    9. Tap Power button to select Reboot System Now.
    Jan 04, 2016 | Tablets & eReaders
    how to reset a factory fasttouch 7inch tablet
    Hard reset or factory wipe is a method of formatting any Android device ( tablet or mobile). By doing hard reset all the apps and files that are installed or created by the user will deleted. Even the memory card will get formatted. So before going for hard reset or factory swipe, it is suggested to remove the memory card if you do not want data to be erased
    For simple factory reset the process is follows:
    Sponsored
    • Goto settings -> Back & reset -> factory data reset
    After factory reset, only pre installed apps and files that came with the device will remain on it.
    Feb 19, 2015 | Android 7 inch Tablet
    172 people viewed this tip
    Top Samsung Tablets & eReaders Experts
    Jaime Hernandez
    Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
