Tip & How-To about Washing Machines
DIY Tension Spring Spreader
DIY Tension Spring Spreader..... for working on front load washing machines.
To work on a front load washer, door seal or lock, one needs to remove the wire/spring clamp from the rubber door seal. It can be removed easily but reinstalling it can be a nightmare, it requires the spring to be extended while slipping the wire around and into a slot.
They sell a tension spring tool for about $45.00 CAN, I made one for about $20.00 and it can still be used as wood clamp in the shop. See attached photo.
I bought a Dewalt 6 inch Trigger Clamp, took out the pin and reversed the trigger, it now becomes a spreader.
Cut the sharp ends off of 2 - 2 inch nails and file a small groove at the ends, they become the spreader posts.
To attach the posts, drill 3 or 4 small holes thru the plastic clamps, then use some wire to fix the posts securely, you may also us some tape to hold the post when there is no tension on the posts.
As you squeeze the trigger it expands the spring, the wire/spring clamp was reinstalled within 30 seconds without damaging the rubber seal.
Now that the washer is repaired I will put the clamp to work in my shop.
Washing Machines Logo
the front door will not lock and pau is flashing on my frigidaire affinity front end loading washing machine and it will not start
You will need to replace your door lock mech.
On the bottom of the door seal lift the edge and locate the retainer spring and remove the spring then remove the door boot,unscrew the door lock disconnect the wirng and replace the door lock mech
Oct 07, 2011 | Frigidaire Affinity ATF7000E Front Load...
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
how do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
106 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
