Tip & How-To about Miscellaneous
How To Fix The HP Printer Error 49? The HP printer 49 error is a result of an internal communication issue where the firm has led to a critical error and the formatter processor has simply aborted its operation. The error also has letters defined as XXXX which refers to the issue of this fault. HP records these messages so that if they have started recognizing a high level of error with the same fault address they can easily focus on making various changes with the firmware or other such parts to help prevent the error from executing on repeated basis. According to HP technical support experts, it is said that the error 49 error is a serious cause of a bad printing command, corrupted data, various invalid operations, firmware, formatter, or even it is possible due to EIO card or memory accessories. Steps to fix the HP Printer error 49 Step1: Power-Off Phase ·Power off the device and then carefully disconnect all the communication cables; Network, USB, or Parallel cable. ·Wait at-least for 30 seconds and then turn the device back on. If the error still exists then it is a possible device error. If the error does not go away then it is a symbol of Communication Between the Computer and Network Step2: Managing the printer ·Unplug the printer and then carefully remove all the accessories such as EIO cards, memory, extra trays, duplexer (if removable), and envelope feeder. ·If the error does not exists after you have powered on the printer, start reinstalling the parts one at a time, by powering off before you go ahead with the installation phase of each part till you find the error cause. Next, the firmware needs to be updated to fix this type of issue. Step3: Further method ·If the 49 error is present in the printer after removing possible causes then try a cold reset or NVRAM initialization method first. A cold reset process will further reset every minor stored memory settings such as control panel settings or internal and external jet direct settings. NVRAM is more elusive as well as clears out all the internal memory such as error logs and other possible counters. ·If this 49 error continues to exists, it is advised by HP tech support experts to replace the firmware DIMM, if there is one. ·Check for a proper service manual for specific 49 errors parts Get in touch with our HP customer support Toll-Free 1-800-213-8289 department for instant solutions to your issues now! We are always there to help you out for any related HP printer error queries.
Miscellaneous Logo
ERROR 49.FF81
From HP support forum possible defective hard drive.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/M3035-MFP-49-FF81-Error-Code/td-p/1272713/page/2
you may be able to disconnect the drive to get the printer operational,
but you lose some functionality
49 errors are communication errors with other devices in printer.
Mar 20, 2014 | HP LaserJet M3027 MFP Printer
Our HP LJ3005Px shows the following error: 49.FF04 Service ne Error What can we do?
Firm ware error issue.If printer comin to ready mode try to up load form ware, no ready mode replace formatter
May 04, 2011 | HP LaserJet P3005 Printer
When the printer is booting it is stuck at **************************, when it do comes on it comes with error code Error 49.4c02 Product model: HP Laserjet 4100N
Thank you for contacting FixYa with your printer inquiry.
HP Laser Jet 4100 49.4C02 Error
49.xxxx PRINTER ERROR
Description 49 errors are generally communication errors or file related issues and can usually be resolved by following the steps below:
Action Turn the printer off, and then turn it on again.
If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card (or any third-party devices), if installed.
Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
Turn the printer on. If the 49 error returns, turn the power off, and then unplug the printer. Remove the formatter board.
Check that the parallel I/O board is firmly installed on the formatter board.
Check for any non-HP memory DIMMs. If any extra memory is installed, remove it.
Reconnect the power cord, and turn the power on.
If the 49 error returns, perform a cold reset.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence. If the error code continues to come back, it requires a firmware upgrade.
If the 49 error returns, contact an HP-authorized service or support provider.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 05, 2011 | HP LaserJet 4350 Printer
49.2F9D error
Hello, An 49.XXXX error relates to an internal critical error, this can be cause by eiter hardware or application related issues.
For more information on 49 Errors follow the posted link.
Support 49 Errors CLICKHERE
Sep 10, 2010 | HP LaserJet P3005 Printer
Hp 5500 dn with 49 4C02 error
Replace the jet-direct card. don't forget to install the IP address on the new card.
Apr 14, 2009 | HP LaserJet 4350TN Printer
39 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
