Tip & How-To about Canon Office Equipment & Supplies
5 Steps to Change Cartridges in Canon PIXMA Mg5220 Printer
    1.Reveal the front paper tray of your printer. Raise the upper part of your print until it goes high as it will reach and close the tab. The cartridge carriage will shift to the middle of the printer.
    2.Press in the back tab on your ink cartridge and raise it. Extract the new cartridge from the packaging, unwrap the plastic chip that keeps the toner feed aperture.
    3.Push the ink cartridge into the slot in the container and press down on end next to you to lock the brace in place.
    4.Pick up the printer upper part and push the bottom of the tab away from you to expose it and then lower the cap. Your printer will then move through different cycles to readjust the cartridges and check the new one is placed correctly.
    5.If you have more than one cartridge dried out simultaneously, follow the steps 2-4 for all ink cartridges before pulling down the lid.
Canon Printer Customer Support Number
t652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
HP Deskjet3845
To remove the jammed sheet of paper :
1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out. CAUTION! The paper may be covered with unfused toner, which can stain garments.
6. If you see no paper jammed under the cartridge, remove paper tray 1. The paper may not have fed all of the way into the printer.
7. Reinstall the paper tray and the toner cartridge.
8. Close the upper front door.
Mar 11, 2009 | HP Deskjet 3845 InkJet Printer
150 people viewed this tip
old marine
old marine
