Tip & How-To about Samsung Cell Phones
How to fix Samsung Note 4 from freezing.
Phone freezing every few seconds. Go settings, Applications, Application Manager, 3 dots at top right, Reset app Preferences.
It was so frustrating as my phone kept freezing every few seconds.
Cell Phones Logo
I am unable to turn off screen overlay. I tried doing so in app settings by turning off all permission. It is still on, how do I remove it. ZTE 798BLi
Hope this help.
1. From your home page go to Main Settings by pulling down the Notification Bar and clicking on the Settings icon at the top right of the screen. (it's gear shaped)
2. Scroll down the Settings menu, and click on Applications under the Phone section about two thirds down the page.
3. At the top of this new menu click on "Applications Manager".
4. In the top right corner of the Applications Manager menu click on "More"
5. Now a click on "Draw over Other Applications"
6. Scroll down this menu and find the offending application, in this example "Facebook"
7. Click on the button to the right of your offending application to deselect it.
8. Close out of the Settings menus.
NOTE: Alternately, deselect all the applications under step 8 except those you know pop up over other applications such as messaging, for example.
Feb 04, 2018 | ZTE Cell Phones
My Facebook keep frezzing and saying Facebook has stopped running. I have a Note 4 .
1-Go to Settings > Application manager
(and scroll to the All tab. Find your Facebook app and tap Clear cache and Force stop).
2-Restart your Note 4, and see if the issue is resolved.
3-Check in the Google+ app. (Tap the three dots at the top right and choose Settings, then tap your name under Account Settings and choose Facebook).
4-Try unchecking Keep Facebook up to date.
Some people report that they resolved the issue by disabling Google+ or uninstalling updates for it.
The options can be found in Settings > Application manager > All > Google+.
Aug 21, 2015 | Facebook Computers & Internet
user fault not kernel panic upload mode
From the Samsung GT-S5300 user manual -
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close applications or reset the device to regain functionality. If your device is still responsive and an application is frozen, close the application with the task manager. If your device is frozen and unresponsive, press and hold the Power key for 8-10 seconds. If this problem persists, perform a factory data reset. In the application list, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
See Troubleshooting section (pg 109) -
http://bit.ly/1Pqin8c
May 07, 2015 | Samsung GT-S5300 Galaxy Pocket
i get app error 523 every time on my blackberry 8220 pearl flip display
On the BlackBerry smartphone, the following error message appears after pressing the Mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, first perform a hard reset.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If this does not resolve the issue, the BlackBerry® Device Software must be re-installed.
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps:
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider
Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps:
  1. Remove the battery and run loader.exe from C:\Program files\Common Files\Research In Motion\AppLoader.
  2. Remember to reinsert the battery after the loading operations begin.
Oct 26, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
app error 200
You need to workaroundthese two step's until the problem is resolved:-
A) Perform a hard reset on the BlackBerry device.
B) Delete and reload the data on the BlackBerry device.
1) In BlackBerry Desktop Manager, open Application Loader and click Next.
2) Verify the correct applications are selected and clickNext.
3) Click Advanced.
4) Select the option for Erase all application data and Erase all currently installed applications and click Next.
5) Click Finish. The data on the BlackBerry device is deleted and reloaded.
Oct 18, 2009 | RIM BlackBerry Pearl 8100
112 people viewed this tip
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
