Tip & How-To about Health & Beauty
Infiniti TS30 Console YouTube 720p
This is a tutorial for the Infiniti TS30 Treadmill Console. After powering on the unit, use the up and down arrow keys to scroll the available programmes. There's manual, a series of 11 pre-set programmes which give you a wide variety of workouts, 2 custom user programmes, heart rate control mode and a body mass index test. Press the mode button to select a programme. You can then set a time limit using the arrow keys. Then press start to begin. During the workout you can adjust incline by using the left hand side arrow keys, you can also use the quick set buttons to go straight to a desired level. The same can be done for speed on the right hand side. On the screen will be displayed your calories, time and distance. If you press the mode button you can then alternate it to display heart rate as well. Keep in mind that you need to have your hands on the pulse grips for heart rate to be shown. Press the stop button to pause your workout, then press the reset button to end and return to the main menu. If you select one of the 11 pre-set programmes you can choose one of 3 difficulty levels. Then set the time, then press start. Quality Fitness Equipment Gym Equipment For Sale Fitness Choice
Health & Beauty Logo
9.33i treadmill asks me password as the unlock
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to
change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Nov 05, 2013 | Precor 933 Premium Series Treadmill
treadmill says fill with wax
Diagnostics is entered by holding the 'PAUSE' key when power is applied or by holding the
'PAUSE' key and pressing the 'CLEAR' key twice from any state.
The unit will take approx. 3 to 4 seconds to enter Diagnostics.
On entry to this state, the message:
USE ARROW KEY TO SCROLL THROUGH LIST till show on ddisplay the option "MAINTENANCE"
USE ARROW KEY TO SCROLL THROUGH LIST when display show the message "replace wax bag" press enter
the display show "repair logged" and exit press the key "clear"
Feb 05, 2013 | Life Fitness 91Ti Treadmill
how to unlock safety code for precor 9.35 treadmill
• Set User Name
Procedure
Sep 27, 2012 | Precor 9.35 Premium Series Treadmill
error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    Color calibration
    You may first want to replace the magenta, but then do this.
    1. Press the Down Arrow and scroll to Troubleshooting.
    2. Press OK.
    3. Press the Down Arrow and scroll to Print Quality Problems.
    4. Press OK.
    5. Press the Down Arrow and scroll to Calibrate Colors.
    6. Press OK.
    7. Scroll to the Tutorial Page using the Down Arrow or Up Arrow key.
    8. Press OK to print this page.
    Dec 07, 2007 | Xerox Phaser 6250DP Laser Printer
    64 people viewed this tip
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
