Tip & How-To about Cell Phones
How to put your Google pixel into Safe mode.
There are two methods to put your google pixel into safe mode.
1. If your Pixel is currently on
  • press and hold the power button
  • once the popup to Power Off or Restart your phone comes up. press and hold the Power Off button
  • Another popup window will appear asking if you want to restart you phone in safe mode
  • You press OK and your phone will restart in safe mode
2. If you Pixel is currently off
  • When you reach the part in the startup process that shows the multicolor dots press and hold the down volume key
  • The phone should start up in safe mode
Cell Phones Logo
Unfortunately Google Play services has stopped message appears on my mobile phone . How do I get rid of it as it comes up after every few seconds
Update Google Play Services to the latest version. You can download from here. You may be getting an error because you have a very outdated version or the one you have is having a conflict/bug with the current Android version in your phone.
Clear the Google Play Services cache. The Google Play Services app in your phone acts like a framework for all the Google and Google Play apps installed in your phone. You can try cleaning up its cache and see if that would fix the issue. This worked with one of our team members! Read these quick and easy steps : Go to Settings > Apps.
Scroll to All apps and then scroll down to "Google Play Services" app.
Open the app details and tap on the "Force stop" button.
Then, tap on the "Clear cache" button.
Clear the Google Services Framework cache. The Google Services Framework system app on your Android device stores information and helps your phone sync with Google servers - and keeps your Google Play Services up and running. This could be one of the reasons why you are not able to connect to Google servers using the app and keep getting the error message. Read these quick and easy steps : Go to Settings > Apps.
Scroll to All apps and then scroll down to "Google Services Framework" app.
Then, tap on the "Clear cache" button. Google Play Services Has stopped message continually popping up on my...
Nov 15, 2016 | Google Cell Phones
I accidentally deleted my Google keyboard
Hi Yvonne
With the smartphone turned on, press and hold the "Power" button
Tap and hold "Power off"
In the Safe Mode prompt, tap "OK". Your smartphone will reboot in safe mode
After the device reboots, the "Safe Mode" label should be present on the screen
To uninstall an app, tap the "Applications" icon while on the home screen
Tap "Settings"
Under "Device", tap "Apps"
Swipe to the "Downloaded" screen
Select the desired application and tap "Uninstall"
Tap "OK" to confirm
To exit safe mode, press and hold the "Power" button > tap "Power off"
Once the smartphone is turned off, press and hold the "Power" button to reboot your device as you normally would
Jul 06, 2016 | Blu Studio 5.0 Mobile Phone
blotted screen in my hp laptop
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
Sep 19, 2011 | Computers & Internet
Pixel
the camera have a service menu that fixed it
first you must be in 24p mode for this operation
press and holding simultaneous the focus assist button(the one on the camera body)and the menu/status button for at least 5 seconds.
you see and advanced menu where the second line says CAMERA 1.
move the cursor down and push the shutter wheel to enter that menu and now you have a list with the six item being PIXEL COMPEN.
move down and select that item, the word CANCEL blinks.
change it to EXECUTE and push again. it takes about 10 seconds or so to perfom the operation and then tells you to power off the camera.
YOU ARE DONE!!
Feb 20, 2008 | JVC GY-HD110U Camcorder
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Press the OK/MENU button and then press the right arrow button to enter the Mode Menu. Press the down arrow button until the SETUP tab is highlighted. Press the right arrow button and then the down arrow button until PIXEL MAPPING is highlighted. Press the right arrow key, which will highlight START. Press the OK/MENU. The back of the camera will display an indicator bar with the word BUSY. Once Pixel Mapping is completed the Mode Menu displays. Press the OK/MENU button to resume normal picture taking. The bright dot should no longer appear in your downloaded images.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
67 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
