Tip & How-To about Audio Players & Recorders
Pioneer VSX-D514 amplifier/receiver not turning on
I would like to thank the person who suggested this method to get my amplifier/receiver to turn on: With amplifier/receiver plugged into the power socket and the mains power turned on, hold down the ENTER and ADVANCED SURROUND buttons together for a few seconds until you hear a click and the LED display lights up.
This worked perfectly for me and it saved me taking the amplifier to a repair shop.
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
Pioneer audio/video receiver damaged
Hi...
The problem is probably that the bad connection "took out" a couple of the power transistors/power mods in the amplifier
If you need a pro to fix it I can suggest someone depending on where you live
Apr 15, 2010 | Pioneer Audio Players & Recorders
sony amplifier/vcr problem
The Dog must have not liked the program? No what you need to do first is check the things that you overlooked as obvious? Such as mute switch, Balance control, Not in the right mode, speakers turned off, Audio cables pulled out of the unit. In tape monitor mode. Thats the most common thing if you have no sound after a bump from the rump of a dog,person playfull partner. Good Luck
Jun 17, 2006 | Sony STR-DE595 5-Channel Amplifier
67 people viewed this tip
 Grubhead
Grubhead
