Tip & How-To about Computers & Internet
The Windows Blue Screen of *****
In the figure you can see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode.
Computers & Internet Logo
BSOD involving Tunnel.sys and ntoskrnl.exe
Deoending on your OS you can find repair disk on-line. Do a Google search of your OS and repair disk iso. Take a look at this for a general idea, at the bottom of the page:http://maximumpcguides.com/windows-7/create-a-windows-7-system-repair-disc/ OR http://maximumpcguides.com/windows-7/create-a-windows-7-system-repair-disc/
Dec 09, 2012 | ASUS Computers & Internet
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus or corrupted boot sector. I have wiped the disc with Boot and Nuke 2.2.6, showed no errors. Tried again with same result. Ran Disc repair with same result. Downloading UBCD as I write this. NOT the XP disc for sure. HDD was running Vista SP2 when problems started.
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Jun 11, 2017 | Sony VAIO VGN-NS140E/S Notebook PC
Blue screen caused by SPCMDCON.SYS STOP:0x000000050 (0xfd3094c2,0x000000001, 0xfbfe7167, 0x000000000) M/c rebooted and blue screened again after about 5 mins this has gone on for an hour before I gave up
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Feb 16, 2010 | Microsoft Windows XP Home Edition
what say you?
Hi beester,
The file you specified is a driver for a logitech webcam and there is a possibility that it's corrupted, try to boot you computer into Safe Mode(if your running windows of course press F8) and try to uninstall or upate the driver for your webcam and check if you will still receive a BSOD(blue screen of death) on your computer. hope this solution fixes your computer problem.
You can also check this link and see if this will solve your problem if the above solution fails; http://www.runscanner.net/files/sys/lv321av/lv321av.sys.aspx
Regards
May 12, 2008 | Computers & Internet
BSOD
Apparently w22n51.sys is an Intel driver. It looks like this problem has been resolved by installing the latest Intel PRO/Wireless 2200BG drivers that you can find here...
http://downloadcenter.intel.com/Filter_Results.aspx?strOSs=All&strTypes=all&ProductID=1637&OSFullName=All%20Operating%20Systems&lang=eng
Another resolution I've seen posted in forums is to disable the Intel software or uninstalling it completely and allowing Windows to mange wireless connection.
Hope this helps!
May 02, 2008 | Gateway 4520GZ Notebook
48 people viewed this tip
David Payne
David Payne
