Tip & How-To about Miscellaneous
How to get soft lips faster while using chapstick
Lick your lips before you put the chapstick on because it'll lock the moisture in.
Miscellaneous Logo
How to threadle the needle
Thread the needle? Just insert the tip of the thread into the needle's eye. If you have vision problems, it helps to lick your index finger and then swipe it across the BACK side of the needle's eye. The thread end is attracted to the moisture and helps pull the thread into the eye. Some sewists swipe the thread tip with chapstick to stiffen it.
How to Thread Needle and Tie Knot
Sep 29, 2016 | Sewing Machines
a very moisture rich lipstick
Faces Moisture Rich Lipstick offers opaque and rich shade to lips and makes them soft all together. The formula is blend of Vitamin E to moisturize and protect your lips with every application. Its intense lip colors enriched with jojoba oil that cover the lips in a higher creamy coat which is long lasting and comfortable.
Nov 13, 2013 | Max Factor Lipstick High Definition Or...
My lips have discolored due to constant picking and they look very ugly. can the color be restored
I would recommend using Burts Bee's chapstick. It's one of the only chapsticks that does not have an ingredient that will INCREASE chapped lips. Upon applying, it's not the most moist of the lip balms, but you will notice a difference over a couple of days. Try the different kinds, and find which one is for you. As for the discoloration, for a quick fix, you can use a lipstain (close to your natural color). I like using NYC's lipstain because it's cheaper, AND stays on just as long. Another tip, try applying a good amount of chapstick and take a dry toothbrush and rub the excess skin/dryness away that way. It will enhance your lip color and scrub away the dry mess. Afterwards, reapply the chapstick.
Hope this helps!
Jun 08, 2011 | Blistex Medicated Lip Balm 0.15 oz Stick
My newborn kittens have this allergy thing
take them to a vet as it may not be an allergy but a disease
Aug 01, 2017 | Casio Watches
46 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
