Tip & How-To about Computers & Internet
Some devices can't connect to the internet
This question was posted to another forum, and it took me FOREVER to find a solution to it. I am sharing this to help the thousands of others who will face this issue. In my case it was a Sony Bravia TV that couldn't connect to the internet even though it was connected to the WiFi, but it could apply to any device:
Hello everyone,
I'm fairly good with comptuers / networking but this issue has me baffled. Help would be greatly appreciated.
I have a linksys router (WRK54G) and have 2 desktops and 2 laptops connected to it wirelessly at the moment. I bought 3 smart phones (AT&T Tilts) and a new laptop recently. I don't use encryption but I do have MAC address filtering enabled.
The issue is that 1 of the smart phones can connect to the network and the internet, but the other 2 phones and the laptop can connect to the network but not the internet.
I did add their MAC addresses to the "allow" list ofcourse, which is why they're able to connect to the network. DHCP is enabled, and these devices get an IP address. I can see them as connected when i log in to my router as well through one of my other computers (I see the MAC address and the IP assigned to those devices) so I know they're properly connected to the network. However, when i try to pull up a website (using either its ip or its domain name), the devices try to open up the page but eventually give me a "The page cannot be displayed or downloaded because the connection was lost" on the pocket PCs, and a generic "page cannot be found" on the laptop. I don't see these requests in the outgoing log table of the router either... I'm supposed to see them as when i use one of my desktops, I can see which site was accessed by which IP.
So basically, the requests from 2 smart phones and 1 laptop aren't even getting to the router apparently. What could be wrong? These devices can access the internet on other routers elsewhere at my workplace or at wi-fi spots.. just not at home, which is a major inconvenience. Why would the router be stopping some devices from connecting to the internet and allowing others? I know it's not a setting in the devices as it can access the internet through other wi-fi spots elsewhere..
Help will be truly appreciated.
THIS POST HELPED IMMENSELY:
This is a more common issue than many would think with so many mobile devices.
The issue stems from the fact that the network interface on portable devices will go to low power mode to save battery life when not active. When it does this, another device could come onto the network and start using the same IP address. When the original device 'wakes up' and tries to use the IP address, it causes a conflict.
With this kind of dynamic addressing, when there is a conflict one of the devices is rejected.
This was a big issue with earlier Apple mobile devices, but can happen with many mobile thing. The wifi spec was just not written well enough to allow multiple devices to enter and leave constantly while avoiding address conflicts.
One was to try to solve it would be to assign static addresses to as many as your devices as you can. If the devices have a static (not automatically re-assigned) address and that address is OUTSIDE the 'pool' of automatic address, the conflicts will stop happening. If you give it a static IP that is within the pool of DHCP addresses the router can hand out, you aren't really solving any thing since the router can still assign another device the same IP which will conflict.
Note: SOME routers will let you 'reserve' certain IP addresses for specific devices. This would also work, since after that the router will only give that address to the device it is reserved for.
Look into the documentation for your devices about how to set static addressing... then look into your router to find out the 'pool' of automatic (DHCP) addresses it will give out. Set your static addresses as ones different than the range from the DHCP pool.
Note 2: Some routers come with REALLY small pools of DHCP addresses configured. My netgear only had the DHCP pool set up as 15 addresses! By my last count, my house has over 20 wifi devices in it now. So of course, things were fighting for addresses constantly. I expanded the DHCP pool to 100 addresses and it made a pretty huge difference.
HOW DID I DO IT on my router. I have a FRITZBOX router, and unfortunately you have to do things in a certain order or it won't work, because you cannot just delete a device that is going through your router if it is active.
1- Try to work out which devices are attaching to your router and the names of them. For the Fritz, you:
  1. Click "Home Network" in the FRITZ!Box user interface.
  2. Click "Home Network Overview" in the "Home Network" menu.
  3. Click on the "Network Connections" tab.
You might be able to see on this screen dual listings for the same active connected device. You want to remove these and re-establish them.
Switch off the offending device completely. Switch off the router or whilst in the Fritzbox user interface go to System>backup>restart. You have to restart the router so you have the option to delete the offending device, without restarting the device, you will not have the option of a delete key. Once the router is back up, go back to the network connections tab as outlined above, and you will see the offending device in the Idle connections section. Delete it/them. Restart your device. Enter in your modem details (SSID) and the password for the modem/router, and the device will reconnect. You should now be able to see it in the active connections area. Click on the writing pen and click on the box where it says 'always assign this network device the same IPv4 address'. This will stop any other device from accessing the same IP address in the future and stop the conflicts. Try this for all your home devices that connect to your modem/router and never have the issue again!
Hope this helped!
Computers & Internet Logo
What are the best techniques for off-page SEO?
Off-Page Optimization Techniques-
1.Link Building:
Refers to the process of getting external pages to link to a page on your website. It is one of the many tactics used in SEO.
2.Social Media Marketing:
organic, inbound strategies that focus on building an appealing identity that naturally attracts visitors.users will share with their social network to help a company increase brand exposure and broaden customer reach.
3.Social bookmarking:
sites are considered as a quality backlink in the eyes of search engines. Quality backlinks help us to increase blog traffic and Google Page Rank.
4.Article submission:
generally refers to the writing of articles that are relevant to your online business and then getting them added to the popular article submission directories.There are various benefits of article submission including advertising, marketing and publicity of your business on the World Wide Web.
5.Directory Submission:
performs for collecting the backing of own site through which own site PR (page rank) is increased in Google searches.
6.Guest post submission:
Guests posts are posts in blogs written by other writers other than the owner. Usually, the guests are allowed to have links to their websites.
7.Forum posting:
Forum websites are online discussion sites or in other words, 'message board'. ...Forum Posting simply means posting new threads or replying to old ones inforums in order to get quality inbound links to a website.
Digital Marketing Agency Sydney
[Content Source - Nemco]
Dec 20, 2017 | Best Computers & Internet
WHO WELL SEE MY QUESTIONS.I DO NOT WANT ANYONE TO SEE THIS ONLY THE PEOPLE WHO ARE HELPING ME .nO ONE ELSE SHOULD KNOW MY BUISNESS .GOT IT
You are posting to a public forum. Everyone will see what you write and in the unlikely event that someone may want to help, your post will disappear from this main page.
After that the question still remains for others to look at forever and will be used in the future to help others. You can however DELETE your posts at any time and then they are gone forever.
you can always remain anonymous as you are now.
Jan 14, 2016 | Office Equipment & Supplies
what does forum mean
A forum is a place where people share thoughts online about a common interest. Typically, you will need to register with the forum and may need to wait to be approved. Once registered, you would login to the forum and read "threads", post to them to share, or start a new thread. A "thread" is generally a term used to describe a topic and it's discussion entries made by various people sharing on that topic. Forums are great places to share information and learn about items of interest.
Apr 30, 2014 | Google Finance
I cannot post anything on my homepage. Once I leave the page I lose what I posted?? The post does show up on my profile page but does not remain on my homepage to share.
go to your wall cuz sometimes you can;t see it but other people can i figured that out the hard wya i have had a facebook forever so TRUST ME
Nov 12, 2009 | Facebook Social Network
67 people viewed this tip
David Payne
David Payne
