Tip & How-To about Electrical Supplies
To prevent inevitable iphone 7 LCD Screen damage and avoid repair costs, invest in phone cases and screen protectors for your iphone 7. Screen Protectors Made from tempered glass, screen protectors safeguard your phone against scrapes and scratches without compromising touchscreen sensitivity or image quality. Phone Cases There are many stores make durable phone cases and covers to provide extra security for your iphone 7 and protect it from scratches, drops, and dust. A good Clean Because your iphone 7's screen is the interface of the device, it is bound to get smudged and dirty quickly from the time spent using it. When cleaning your screen, never use a chemical cleaning solvent. Instead, use water and a clean, lint-free, scratch-resistant cloth, such as microfiber. Dampen the cloth-not the screen-and gently wipe off with even strokes. For Apple iPhone 7 LCD Screen and Digitizer Assembly with Frame...
Electrical Supplies Logo
my touchscreen android phone hasn't turn back on for 2 weeks,is there another way of fixing it without a repair man
As you probably already know, there are almost an endless number of ways that your iPhone can come into contact with moisture. For example, recently, I had my iPhone 4 in my back pocket when it accidentally slipped out when I had my pants down using the toilet. Don't ask ! There is some good news however, and that is in most cases, a wet iPhone repair can be made without your having to buy a new one. Yes, dropped iphone in toilet is very, very common.
The terrific news is that all models of iPhones can usually be repaired after sustaining water damage, but this must be evaluated on a case by case basis (in my case, my iPhone could be repaired for a nominal charge).
Fortunately, iPhones consist of parts that can be readily swapped out for good ones. If, however, your iPhone has been fully submerged in water or other wet substances, chances are that the logic board in your iPhone has been exposed to moisture and corrosion has begun to take place.
If the logic board is damaged, the cost of the repair can get quite pricey, especially if other parts also need to be replaced on your iPhone. The logic board is the main circuit board in the iPhone that runs the operating system and stores all data on the iPhone. The logic board is not typically too expensive to replace on its own, however, coupled with other parts that might also need to be replaced, the cost for repair may run you a pretty penny..
Nov 01, 2012 | Cell Phones
broken glass touch screen to iPhone had a screw drive in pocket with iphone and it broke the touch screen glass
Here's some info about your iPhone display repair:
Repair/replacement from Apple: $200-$250 The iPhone is covered under a standard limited one-year Apple warranty for manufacturer's defects, but is not eligible for AT&T's wireless phone insurance, which (for a $5 monthly fee) will provide replacement in the case of loss or theft, accidental physical or liquid damage or mechanical and electrical failure after the manufacturer's warranty period has expired.
Apple will repair your iPhone for the service fee listed below, plus $6.95 for shipping and handling:
  • 4GB: $199
  • 8GB: $249
Do-it-yourself: $150-$200 tools and loss of your warranty Several third-party companies sell replacement iPhone screens, which include the LCD and associated components. PDAParts sells the complete replacement screen for $150 and has a how-to-video for self-installation.
Hope this helps.
Jan 09, 2010 | Apple iPhone 3G Black Smartphone
I dropped my iphone, screen is in tact, slide bar won't work
you can get the slide part changed . it could cost you anywhere near 100 $
Oct 21, 2009 | BoxWave Corporation Apple iPhone 2G...
Broken 3G screen
never used them or bought anything from them
sells screens for $149 and installes it for $50 more
Feb 21, 2009 | Apple iPhone 3G
102 people viewed this tip
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
