Tip & How-To about Microsoft Windows 7 Home Premium X64 Edition 1 Single PC Easy To Create A Home Network Popular
Set up a new Connection or Network
Creating the Network
Opening?the?Networking?and?Sharing?Center. You can launch the Network and Sharing Center in three ways . One way is to click the network icon from the right side of the taskbar, then click Open Network and Sharing Center .
A second (and the quickest) way is to launch the Run window by pressing the Windows key+R, typing control.exe/name?Microsoft.NetworkAndSharingCenter, then clicking OK .
A third way is to choose Control Panel?->?Network And Internet?->?Network And Sharing Center .
The Network and Sharing Center window is split into two areas . On the left side, there is a column containing shortcuts toward tasks, such as managing your wireless networks, changing settings for all network adapters, and changing network sharing settings . On the bottom of the same column, there are shortcuts to the Homegroup settings panel, the Internet Options panel, and the Windows Firewall panel . On the right side, you have basic information about the current network connection and links to several wizards that allow you to change some of your network settings .
Microsoft Windows 7 Home Premium X64 Edition 1 Single PC Easy To Create A Home Network Popular Logo
need help sharing the internet on my laptop from another laptop
On windows 7
Go to Control Panel > Network and Internet > Network and Sharing Center
Under Change your networking settings, click Set up a new connection or network
Select Set up a wireless ad hoc (computer-to-computer) network
Enter your Network name, and enter a Security key if wanted
Check the box for Save this network and click Turn on Internet connection sharing on next page
From your other laptop search for networks and you will find the one you just created, connect to it and use the security key you gave..
May 13, 2011 | Computers & Internet
networking, file sharing
hello
right lick on the internet icon right side down of your monitor screen and select open networking sharing center and at the left side upper corner you see change advanced sharing center click for that one and turn on your TURN ON NETWORK DISCOVERY AND FILE PRINTER SHARING.
Thanks
Mar 07, 2011 | Microsoft Windows 7 Home Premium 64BIT...
cannot connct to wi fi
A guide in .PDF format has been included on your hard drive that provides instructions for installing and configuring both wired and wireless Ethernet networking on your notebook. To access this guide on your hard drive, from the Start menu, point to All Programs, Gateway Documentation, and then click Gateway Networking User's Guide. The following are some of the topics included:
  • Learning the Basics
  • Creating a Wired Ethernet Network
  • Configuring Windows for a Wired Network
  • Configuring Windows for a Wireless Network
  • Creating a Wireless Access Point Network
  • Creating a Peer-to-Peer Wireless Network
  • Turning Your Wireless Emitter On or Off
  • Sharing Your Resources
  • Troubleshooting Your Ethernet Network
A copy of this guide is also included on your Application and Drivers CD.
Dec 18, 2010 | Gateway Tablets & eReaders
I have the WRT54G router. I got an adapter for my USB Printer cable to Ethernet to connect it to the router. I have a wireless laptop that I would like to use to send the print jobs to the printer (a PSC750). Is there a software program or driver that I need to make this work?
Connecting to a Wireless Network with SSID Broadcast Disabled when using Windows Vista & Windows 7 Article ID: 5451
Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled, you will have to create a profile.
Creating a Profile
NOTE: Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled you have to create a profile.
Step 1:
Right-click this icon kb_5451-001_en.png at the bottom right-hand corner of the screen, then select Network and Sharing Center.
NOTE: If you are using Windows 7, just click once on this icon kb_5451-003_en.png at the bottom-right of the screen then select Open Network and Sharing Center.
On the Network and Sharing Center window, click Manage wireless networks.
Step 3:
Click Add. NOTE: You have to remove your preferred network before before you proceed to click Add a new connection. If you see your network has changed from Automatic to Manual, you will face difficulties to connect your computer on the network because the SSID is not broadcasting into the available network connection. After removing your preferred network and adding it back, the network will turn to Automatic and you will be able to connect automatically into your network. Make sure to look at network properties/Connection and check "Connect when this network is in range".
Keep reading here
Jul 10, 2010 | Linksys Wireless-G WRT54G Router
159 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
