Tip & How-To about Miscellaneous
3 Quick Solutions to Repair Juno Webmail Script Error message
If you have an Ad-blocker or a popup blocker installed on your computer system, you may get many script error messages while connecting with the Juno Webmail. You can prevent these mistakes from encountering by configuring the pop-blockers / ad-blockers correctly. If you're often getting a Script error message whenever try to start Juno or log into the webmail account, then you will require configuring the ad-blocker programs to operate with Juno webmail; otherwise, you may face the Juno sign in problem. There are three methods to do that:
    1.Add Juno Mail to the exclusion list of your ad-blocker
    2.Set up the ad-blocker to enable banner ads
    3.Disable the filtering feature in the ad-blocking program If you're using the AdSubtract tool, you should follow the instructions given below. In the case of any other pop-up blocking or ad-blocking software, refer to the documentation of your blocker tool for the accurate guide on configuring the software to enable ads from Juno Mail. You can get connected to the Juno webmail support experts and solve these error messages in a proper manner.
    Solution 1 - Insert the Juno Webmail to the Bypass Site list
    If you want to add the Juno website into an exclusion list, right-click anywhere on the web page and choose the 'AdSubtract: Bypass Site' option. You may require repeating this procedure on other Juno web pages on which you get the script error messages. On the other hand, speak with the Juno professionals to repair your email account issues.
    Solution 2: Configure AdSubtract to enable banner ads
    This solution will fix the script error messages that can prevent you from accessing your Juno email account, but will also cause in other banner advertisements showing on other websites you access.Here's how to setup AdSubtract software to allow banner ads.
      1.Launch the AdSubtract program and click on the 'Block' icon.
      2.Deselect the Banner Ads field from the selection on the left.
      3.Click the 'OK' button to save and apply the changes. If this workaround doesn't work and you're still getting the script error messages, then either you can get in touch with Juno customer care executives or go to the next.
      Solution 3: Disable AdSubtract tool filtering
      This workaround not only resolves the script error messages for the Juno webmail site but also causes in disabling all of the AdSubtract's filtering efficiently.
        1.Launch the AdSubtract tool.
        2.On the main dialog window, click on the 'Disable Filtering' option under the 'Ad Blocking' section.
        3.Click the 'OK' button to save and apply settings. However, if you still have any kinds of technical issues with your Juno email account, or continue to face the script error even after attempting all these solutions, or any further queries, it's highly recommended to call on the Juno webmail support phone number and ask the help to solve all Juno-related issues within a short span of time.
Juno Customer Support Phone Number
Miscellaneous Logo
We are getting dozens of pop-ups and can get rid of some of them
Popups are annoying messages or advertisements that literally "pop up" while you are on the Internet.
They use to be a huge problem, but with the releases of newer software to block them, they aren't as bad.
When a user is on the Internet, and a new window opens up without them meaning for it to, and there is an ad in the new window that popped up.
That is a popup. To get rid of popups, you're going to need some kind of popup software to stop them from appearing.
Search the Internet until you find a trustworthy Internet popup utility.
Be sure it comes from a reputable downloading source and has good reviews before you download it though.
There are scam softwares disguised as popup blockers, but these will actually add more popups.
Try the Google toolbar (there is a link in the Resources).
This service is made by Google and since they make a lot of internet advertisements, it makes sense that they know how to block them.
Just navigate to the install website and let it install.
The service is free and is automatic.
It will block most popups and includes a search bar linked straight to Google so you don't have to go to Google's website to search for things.
You can use that search bar.
Give the Yahoo toolbar as well (See link Below).
Their toolbar is free and also has a popup blocker.
Like Google's toolbar, they offer a built in search engine in it.
Their's has a spyware searcher as well though. It can scan your computer for spyware which one of the causes of popups.
Download and try Smart Popup Blocker if you aren't satisfied with other services.
This doesn't add a toolbar to your web browser like Yahoo or Google.
Instead, it is software that runs in the background of your computer and blocks popups to the best of its ability.
It only works in Internet Explorer though.
You also might want to install antimalware and superantispyware
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
Sep 13, 2013 | Computers & Internet
why i diD n0T uSe thE fAcebook siTe????
Do you have any ad-Blockers? what is your firewall? any popup blockers?
you may need to allow the website through your firewall if its not windows firewall
if you have windows Firewall then an ad blocker/popup blocker is blocking it, allow www.facebook.com through that or turn off your ad blocker/popup blocker
Q: why would an ad blocker/popup blocker block Facebook?
A: Facebook contains elements that are often identified as ads or popups, Most of the content are popups/ads, and as such since the entirety of Facebook runs off popups/ads, that is blocked as a result of being identified as unsafe, do not be surprised, some websites are blocked like this that are actually safe and are otherwise known as False Positives in terms of spyware, viruses, Potentially unsafe websites, etc
Q: Is there a solution? A: Yes, uninstall your popup/ad blocker IF you havent bought actually bought it and download and install Peerblock: http://www.peerblock.com/
for your reference i have mine set to block: Anti-p2p Spyware Advertising
and if you use Google Chrome or something that uses Google Chrome Extensions, install this, it doesnt block Facebook, but blocks all ads and saves your download bandwidth, i cant recommend this extension highly enough :) : https://chrome.google.com/extensions/detail/gighmmpiobklfepjocnamgkkbiglidom?hl=en
tell us how you go
Apr 20, 2010 | Facebook Social Network
i have got a pop up blocker in my adware browser, how can i remove it
  1. Go to the Tools menu and click on "Internet Options"
  2. Click on "Privacy"
  3. To disable all popups:
  4. #* Uncheck the "Turn on Pop-up Blocker" box.
  5. To disable popups on just one site:
  6. #* Click on "Settings"
  7. Enter the URL of the site for which you would like to allow popups
  8. Click "Add"
  9. Close the window
  10. Click "Ok
Thanks for using Fixya
Sep 01, 2009 | Dell Dimension 2400 PC Desktop
log in error message
For a permanent solution, I enabled back ad blocking in IE7 Pro, accessed the Yahoo Mail account (got again the errors), and when I got the "Click here to try again" page, I used IE7Pro context menu to select "Ad Blocker / Don't filter this site".
this can also be caused when you have other ad blockers installed on your computer and also firewalls
Nov 05, 2008 | Yahoo Mail
123 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
