Tip & How-To about Electrical Supplies
I went with this replacement screen when i cracked my original, I've also replaced my wifes iPhone 5 LCD screen so I've had some experienece. Right off the bat, you need to take your time when replacing these. Any one thing can go wrong and thats where I feel a majority of the bad reviews for this product stem - people dont know what they're doing, rush it and cut, crimp, bend, or break something. You will need to remove things from the original screen like the metal backing, clear plastic camera hole, rubber piece for ear slot, wire mesh for ear slot, grounding tape (attached to original screens metal backing), etc. Any decent youtube video will tell you this. If you want your replaced screen done properly, do this. You will need to add a straight edge blade to your tool arsenal, doesnt need to be sharp but a box cutter blade is ideal for working the screen out of the housing (just above the headphone jack is the place to work the blade in between the housing and the screen). Then use the provided plastic tool to work around the edges to fully remove the screen. I wont lie, even with experience, after putting my new screen in, I had blue lines show up initially, I went back to the screen connections on the motherboard and rechecked them. After loosening the metal plate a bit the screen worked fine. I tightened it way too tight, drive them in so they're snug, not like they're keeping the wheels from falling off your car. You will also need a work area to keep track of all the little pieces, if you have parts left over you did something wrong. Also, when fitting the screen back into the housing, run your fingers down the side touching the screen and housing, with slight force, do not push on the middle of the screen! What I didnt know - restart your phone after completion to ensure the finger print reader on the home button works! This thing is very sensitive and any loose connection will botch it. Not realizing this and figuring I did something wrong, I spent way more time then i shouldve troubleshooting... All I needed was a fresh phone restart and finger prints worked like a charm. PROVIDED this was my original home button, that was attached to my original motherboard. IF YOURE REPLACING YOUR ORIGINAL HOME BUTTON FINGER PRINT ID WILL NO LONGER WORK! This apple replacement parts worked like a charm for me, and for $30 thats pretty awesome. Becareful, watch a couple youtube videos, and good luck! Apple IPhone LCD Screen Digitizer Assembly Replacement Parts Wholesale
Electrical Supplies Logo
i phone 5 i cracked the screen inthen replaced with new now all i het is a blank screen can anyone help with a solution plaese
Iphone 5 has a very different screen than the previous ones. In order to replace a broken screen, the entire lcd has to be replaced. You might have not connected all the wires from the new lcd to the motherboard, or you didnt replace all of the parts necessary
Nov 10, 2013 | Apple iPhone 5
iphone 4 screen
hi friend,if you have any problem with Phone repair ,please add my whatsapp:+86-18300007189,all the help is free ,and we have high quality IPhone LCD with Lifetime Warranty and we are paypal elite Merchant in China,reply me to know more:)
ETtrends The Leading Integrated Service Provider of Mobile Accessories
Nov 27, 2012 | Apple iPhone4 4G iPhone 4
83 people viewed this tip
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
