Tip & How-To about BFG Technologies BFGEGTX260MC896OC2BE NVIDIA GeForce GTX 260 OC2 MAXCORE 55 896MB GDDR3 PCI Express ... Video Card
Alienware M17xR4 laptop, Nvidia GeForce GTX 675M to 980M upgrade
Updated the GPU from Nvidia GeForce GTX 680M to 980M. It currently isn't showing up as being installed through "Device Manager" it just says "Standard VGA Graphics Adapter" where it previously said "Nvidia GeForce GTX 680M". In the BIOS it says Nvidia GFX. My "GeForce Experience" isn't working although i try to manually install the driver.
The AMD/NVIDIA video drivers can normally be uninstalled from the Windows Control panel, this driver uninstaller program was designed to be used in cases where the standard driver uninstall fails, or anyway when you need to thoroughly delete NVIDIA and ATI video card drivers.
Solution:
Download Display Driver Uninstaller DDU - Display Driver Uninstaller is a driver removal utility that can help you completely uninstall AMD/NVIDIA graphics card drivers and packages from your system, without leaving leftovers.
Display Driver Uninstaller Download version 17.0.6.1 - http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Still not working:
Solution:
1/ Go to Device Manager
2/ Select the GPU (in Windows 7 it will be listed as "Standard VGA Adapter", in Windows 8.x or Windows 10 it will be listed as "Microsoft Display Adapter")
3/ Double click on it and select the 3rd tab labeled Details
4/ Select the second item from the drop down menu labeled Hardware IDS
5/ The end of the second line will list the machine ID, as the last set of numbers.
Drivers:
depending on hardware ID of the GPU - M17xR4_05511028_9xxM_378.49.zip
BFG Technologies BFGEGTX260MC896OC2BE NVIDIA GeForce GTX 260 OC2 MAXCORE 55 896MB GDDR3 PCI Express ... Video Card Logo
ibm 865g chipset VGA drivers for WINDOWS 7 PROF.
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or you might need to download one
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630932.htmlI Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630939.html Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs.What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature hope this helps
Sep 20, 2011 | Intel 845GE Motherboard
i have a Intel 845 motherboard. recently i installed windows 7. when i play games, i get a message that "hardware acceleration is either disabled or not supported by your video card driver". please help.
click start right click on computer select properties device manager scroll to display adapters if you see a yellow question/exclamation mark or a red X the driver will need to updated/reinstalled
right click select update driver if your computer came with a motherboard disk the drivers could be on it or you might need to download the drivers compatible to run your games or a hardware accelerator driver
you should browse through all of the devices to make sure the drivers have no yellow or red x's on them
http://download.cnet.com/intel-graphics-accelerator-video/3000-2098_4-10163616.html
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUsIncreases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature
hope this helps you
Sep 15, 2011 | Intel D845GVSR Motherboard
I want to install my nvidia geForce 5500 for win7 please help
insert the card into the pci slot on you motherboard turn your computer on the found new hardware should activate and ask you to install the drivers/software for it
if you need more help with this post a reply
hope this helps you
Sep 11, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
After I install the gtx 460 the drivers dont seem to be working and it shows a warning sing in device manager
If these on the driver's that came with the package then I suggest you download the latest version available at the Nvidia download center here.
Just select the following from the drop-down boxes.
Product Type: GeForce
Product Series: GeForce 400 Series
Product: GeForce GTX 460 SE
Operating System: Your current operating system.
Language: The language that you want the setup to be in.
Then click the search button.
Click download on the next page. Once downloaded, run the setup and it will install the driver. You will need to restart to finish the process.
Slasher_X
Jul 07, 2011 | Evga GeForce GTX 460 SE dle Video Card
82 people viewed this tip
Top BFG Technologies Computers & Internet Experts
Josh Levin
Josh Levin
Bill Boyd
Mister Danger
Are you a BFG Technologies Computer and Internet Expert? Answer questions, earn points and help others
