Tip & How-To about Cell Phones
How to bypass Google Account Verification in Android Version 5.1 +
After the phone has finished its factory reset it will reboot and you will be prompted to choose the desired display language. After choosing the correct language please follow the next steps:
  • Connect the phone to a Wifi Network
  • The next screen will ask you for the Google Account
  • Tap the text field in which the account should be inserted until the Keyboard comes up
  • Tap and hold the "@" character until a Settings menu pops up
  • Select Google Keyboard Settings
  • Tap on the 3 dots in the top part of the screen (or More depending on what Android OS you are running)
  • Select the Help&Feedback item and select any item in the list that will follow
  • Long press to select any text on this page and click on Websearch in the upper right corner
  • A search field will be shown (delete the text inside the search field)
  • Type Settings in the search field
  • Tap "About Phone" and tap 7 times on the Build Number to enable Developer Options
  • Return to the previous menu and open the Developer Option that just appeared
  • Allow OEM Unlocking and tap Back two times
  • Restart the device
  • Connect it to Wifi again
  • Notice how you won't be prompted to log in the previous Google Account and instead the phone will ask you to ADD a new Google Account
  • SOLUTION 2 FOR ANDROID 5.1
    1. Connect the phone to a Wifi Network
    2. The next screen will ask you for the Google Account
    3. Swipe down the notification bar to give you access to Settings Panel
    4. Type Settings in the search field
    5. Tap "About Phone" and tap 7 times on the Build Number to enable Developer Options
    6. Return to the previous menu and open the Developer Option that just appeared
    7. Allow OEM Unlocking and tap Back two times
    8. Restart the device
    9. Connect it to Wifi again
    10. Notice how you won't be prompted to log in the previous Google Account and instead the phone will ask you to ADD a new Google Account
    Cell Phones Logo
    bypass frp lock coolpad 3622a android version 5.1.1 how to
  • Nov 13, 2016 | Android Cell Phones
    how do i do a hard reset on cubot s208
    Phone reset:
    Power off the phone, hold the volume down key and press down the power button simultaneously for about 15 seconds. The phone will power up and shows an exclamatory mark. Then release the button. Press the volume down key, it will display the menu. Choose the menu by press the volume down key. Choose "wipe data/factory reset", press power key to enter in, then choose "delete all user data", press power key to confirm. Wait until it indicates "data wipe complete". Then choose "wipe cache partition", confirm with power key. Wait for a few seconds, the screen will shows "cache wipe complete". And at the last, choose "reboot system now", confirm with power key, then the phone will reboot.
    Feb 16, 2015 | CUBOT Cell Phones
    aspire zg5
    aspire netbook to factory defaults Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. or Click on the Start menu. Then, select all programs, Acer Empowering Technology and Acer eRecovery Management. If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD. Click the Restore button and select the option that reads "Restore system to factory defaults". Wait for the computer to finish the restore process and reboot. Restoring for the Boot Screen If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time. When the eRecovery menu appears, choose "restore system to factory defaults". Wait for the recovery process to complete and the computer to restart Hope this helps.
    Jan 21, 2013 | Acer Aspire 5720-6661 Notebook PC
    i wont to restart from factory
    If you need more help with this post a reply
    Hope this helps.
    Jan 11, 2013 | Acer Aspire One PC Notebook
    restore to original settings
    Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. Hoe this helps.
    Dec 13, 2012 | Acer Aspire One AOA150-1029 8.9-Inch...
    120 people viewed this tip
    Top Cell Phones Experts
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
