Tip & How-To about Computers & Internet
How to Find a Compatible RAM Upgrade for Your System?
Upgrade Computer System Memory through PC Configurator Tool
PC System Configurator gives you the extra liberty while buying RAM. Sifting through RAM modules is easier because all are appearing on a single page. And most of all, these all are compatible with the model selected.
With the help of Memory4Less Configurator you can find the compatible RAM for Computer System by using these steps:
  • First note down the series and model number of your system.
  • Go to Memory4less System Configurator page
  • Select Brand>Category>Series>Model
  • On the Model selection page, choose the size of the RAM upgrade
  • Add it to CTO
Computers & Internet Logo
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
Need to upgrade my Compaq Presario 5000's RAM and HD. Need suggestions.
Try to go to this site and use the compatibility tool and see if that points you in the right direction. Although it won't mess up your system to install the wrong ram it could be a costly mistake to order the wrong ram.
http://crucial.com/
Jan 19, 2009 | Compaq Presario 5000 PC Desktop
hello!
I think the best solution to your problem would be either to go to www.crucial.com or www.tigerdirect.com . They both have memory configurator tools that will make sure the memory that you are purchasing is compatable with your laptop. That is your safest way to know. I myself prefer tiger direct, they seem to have the lowest prices. the link below will take you right to the memory configurator. If the DDR333 is an option it will let you know. Hope this helps! :)
http://memoryselector.cnetchannel.com/tigerdirect/
Oct 09, 2008 | Compaq Evo N610C Notebook
Ram For Packard Bell Argo C -
my wife owns one of these computers and it is identicle to my advent 7201 laptop. both have been up-graded to 2 GB with memory purchased from 7dayshop.com (2 x 1GB)ddr2 memory. go to crucial.com and use their memory tool to advise. I do not know if it will take 4 GB? it used to be like wading thru treacle, with 2gb and removing some of the start-up programs it sings, regards HTEETH
Jul 17, 2008 | Computers & Internet
Dell Dimension 8250 Memory Question
Computer Memory Information Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory. How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
Determining what type of memory to use in a memory upgrade. Determining what type of memory to use in a memory upgrade? Question:. Determining what type of memory to use in a memory upgrade.
E-mail CHID: 5683
Good Luck read and follow instructions will find your answer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Dimension 8250 PC Desktop
110 people viewed this tip
David Payne
David Payne
