Tip & How-To about Health & Beauty
Perfectly Cleaning Your Nebulizer
Many people do not learn the perfect way to clean a nebulizer and commit a few mistakes that might damage the nebulizer
    ·Nebulizers are closed and sterile systems and hence you should wear specified gloves or clean your hands before cleaning the device.
    ·People many a time use hot water to clean the mouth piece and hence damage the piece. Always be sure to use warm water
    ·Always let the pieces of the nebulizer dry naturally and do not subject them to any kind of heat.
    ·Not all nebulizers need to be washed with soap and so always take care while cleaning any nebulizer. Ask your doctor or refer to the instructions on the box. Refer to this article, for further details on how to perfectly clean your nebulizer.
    http://www.shopnebulizer.com/ar-Neat-and-Clean-Perfectly-Cleaning-your-Nebulizer.html
    You can also subscribe to our newsletter for more information:
    https://www.healthproductsforyou.com/Newsletterpreference.htmlI
Health & Beauty Logo
pulmoMate nebulizer will not create mist
Make sure your unit is clean and you have a clean filter. Tighten all of the connections. make sure your medication is mixed properly as well.
Apr 20, 2010 | DeVilbiss PulmoMate Aerosol...
need the manual for this nebulmizer 626 m,odel
look up respironics.com you may be able to use the e-learning
Jul 31, 2009 | Inspiration 626 Compressor Nebulizer...
RESPULES Question
No, PULMICORT RESPULES should only be delivered through jet nebulizers. Jet nebulizers are the only effective device for delivery of suspensions such as PULMICORT RESPULES. Because of their physical characteristics, suspended drug particles are generally poorly nebulized in ultrasonic devices.
Aug 27, 2008 | CARE Devilbiss 800C Pediatric Reusable...
nebulizers problem
There are two main types of nebulizers: jet and ultrasonic devices. Jet nebulizers form droplets by using a compressor to deliver a pressurized jet stream of air down a narrow tube and through an opening. This creates a vacuum (through the Venturi effect), thus drawing liquid from a reservoir. The resultant small droplets of liquid are propelled out of the machine by the continued jet stream. Ultrasonic nebulizers produce aerosolized droplets using high-frequency sound waves generated by a special crystal. Liquid drug is usually delivered to the crystal, where it forms a thin layer. Electricity excites the crystals, causing them to vibrate at extremely high frequency. This vibration forces the thin liquid layer through an adjacent mesh, creating a fine mist. Droplet size varies with the frequency of the sound waves created by the vibrating crystals.
Aug 27, 2008 | Cardinal Airlife Brand Modudose 5 Ml Unit...
nebulizers question
Nebulizers deliver aerosolized liquid medicine by a facemask or mouthpiece. Successful nebulizer therapy does not depend on significant patient cooperation or coordination. This is useful in the treatment of pediatric asthma, and the NIH recognizes the nebulizer as an effective delivery device for young children.
Aug 27, 2008 | Cardinal Airlife Brand Misty Max 10...
88 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
